Weber 32/36 Power Valve - JeepForum.com
post #1 of 1 Old 07-21-2006, 09:58 PM Thread Starter
Hunt_Nevada
If you've read other threads on carbs, you may have noted I have an issue with my Weber 32/36 draining out and having to be pumped full-up if it sits for more than a few hours. Anyone familiar with this carb know how much of a pain it might be to get to the power valve to clear it or check/replace the diaphragm? I suspect its got something fouling it or a minor hole in the 'phragm. I know that the power valve is not part of a rebulid kit - the design apparently doesn't fail enough (except for me ) to warrant inclusion. I've seen the diagram and the power valve assembly is a spring-thingy that may be jammed with grime, broken spring, or have a bad 'phragm.
Appreciate any knowledgeable responses, or wild-azz guesses!
'85 CJ-7 258 w/Hedman hedders, DUI ign, 2.5" cat/exhaust, Weber 32/36, T-176, Dana 300, Powertrax locker, 32/11.50 muds, Skyjacker 2.5" suspension, Warn 9500HS - a hunter, not a crawler
Hunt_Nevada is offline
CTO Valve,PVC and Weber 32 36 chuckwag Jeep CJ Forum 6 12-09-2009 08:10 PM
Power Valve ?'s derrick7mm Jeep CJ Forum 4 01-26-2009 05:45 PM
Fixed! Poor mileage (and power) with Weber carb 1337-J33P Jeep CJ Forum 0 03-07-2007 03:05 PM
Power Valve Fropleyqk Jeep CJ Forum 16 02-24-2007 07:56 PM
Poor mileage (and power) with Weber carb 1337-J33P Jeep CJ Forum 22 02-06-2007 09:01 PM
