Weber 32/36 dgev problems and vacuum lines - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Weber 32/36 dgev problems and vacuum lines
Engo winches available at www.rockridge4wd.com! Free shipp8.8 Swap Kit w/ TRUSS for JeepsBlackMagicBrakes 7% Discount, Save today!
Unread 02-08-2009, 11:50 AM   #16
mcmud
1983 CJ8
That would be from what they control. If the upstream downstream tubes are in place when you remove them you will have a hole to weld closed.
mcmud is offline   Reply With Quote
Unread 02-08-2009, 04:01 PM   #17
keith460
Jeep. There's Only One
keith460's Avatar
There are a few sensors and wires that don't get used once you either "Nutter" or rid yourself of the MCU unit. Off the top of my head- Knock Sensor, 02 Sensor, Thermal Electric Switch, Wide Open Throttle Switch and Coolant Temperature Switch. You should keep your EGR, Intake Manifold Heater, CTO and Evap system.
I kept my stock distributor, just upgraded it to the "Team Rush" mods as it is a better than HEI, or so I have read.
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is offline   Reply With Quote
Unread 02-08-2009, 04:17 PM   #18
jatepper
jatepper's Avatar
Keith, I just posted another thread in the forum specifically regarding this vacuum line stuff. Please take a look and let me know what you think.
Thanks,
JT
1985 Jeep CJ-7
Automatic-258 I6- Detroit lockers front/rear - Superior 1-piece axles, Ramsey Pro 9000 Winch, Quick Disconnects, 33 BFG AT's, 4.10 gears, Howell TBI, DUI HEI Ignition, Ground Pounder Rear Bumper / Tire Carrier Combo, Handen Fab integrated winch plate front bumper w/hoop, ORF weld-in front sport cage.
USMC 1999-2004 Semper Fi!
Hood Hi-Lift Jack Mounts for CJ/YJ/TJ/JK
Torchmate CNC Plasma Table Build / Projects
The Target Man, LLC - AR500 Shooting Targets
jatepper is offline   Reply With Quote
