Weber - Page 6 - JeepForum.com
post #76 of 183 Old 05-08-2013, 12:17 PM
uptillnow
uptillnow's Avatar
Originally Posted by Matt1981CJ7 View Post
Glenn,
We should visit the Opel forums to get rid of our 32/36s. I understand they love them in their little 1.9L rice burners.
Matt
You guys are killing me...
The Opel guys run the 38-DGES... they know better!
UPTILLNOW
uptillnow is offline
post #77 of 183 Old 05-08-2013, 12:27 PM
swatson454
1983 CJ7
UPTILLNOW
Maybe a Volkswagon forum. Oh wait, they run dual IDAs.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #78 of 183 Old 05-08-2013, 12:45 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
UPTILLNOW
They roll in Opels, how much could they possibly know?
Matt
Matt1981CJ7 is offline
post #79 of 183 Old 05-08-2013, 02:05 PM Thread Starter
GlennLever
GlennLever's Avatar
Glenn,
Matt
I am going to install the 38. If it runs well I will return the 32/36 for them to look at as I would not feel right about selling it in it's current condition. If a problem is found and fixed I will then sell it.
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
post #80 of 183 Old 05-08-2013, 02:53 PM
swatson454
1983 CJ7
Glenn,
I saw that my video wasn't working. If you weren't able to view it, hopefully this will work. http://api.viglink.com/api/click?for...13680462767759
Full screen is better.
Edit: Apparently, you still might have to refresh a time or two. Sheesh
post #81 of 183 Old 05-08-2013, 03:27 PM Thread Starter
GlennLever
GlennLever's Avatar
Originally Posted by swatson454 View Post
Glenn,
It worked fine for me?
Glenn R. Lever
My Web Site
post #82 of 183 Old 05-08-2013, 03:44 PM
swatson454
1983 CJ7
Oh good. I think I have photobucket fighting me, not sure. Sometimes pics and videos are there and the next day they aren't.
Carry on, gents
Shawn
post #83 of 183 Old 05-20-2013, 10:06 AM
uptillnow
uptillnow's Avatar
Great day to anyone reading this....
Well it has been awhile since we heard from Glenn Lever and his upgrade to the Weber 38-DGES carburetor.
Anyone heard from him?
Waiting patiently for a check-in.
OK, maybe not so patiently.
UPTILLNOW
post #84 of 183 Old 05-20-2013, 11:06 AM Thread Starter
GlennLever
GlennLever's Avatar
UPTILLNOW
It arrived this past Friday, great service from Red Line in the shipping.
Went racing on friday night and Saturday.
I did not get it install yesterday, but am working on it right now.
The throttle linkage was different so swapped that over.
The studs in the top do not reach the air filter adapter, and the threads are different from the bolt for the air cleaner adapter, I am currently drilling tapping them to the correct size. should know more later today
Glenn R. Lever
My Web Site
post #85 of 183 Old 05-20-2013, 11:36 AM
keith460
Jeep. There's Only One
keith460's Avatar
Care to elaborate a little bit on those subjects? Any pics?
I'm waiting to see how your Weber 38 installed before ordering mine.
1984 CJ-7 Renegade
keith460 is offline
post #86 of 183 Old 05-20-2013, 12:21 PM
uptillnow
uptillnow's Avatar
Hey Keith,
The 32/36 DGEV has larger diameter holes or studs in the top of the carb to mount the air filter. the 38-DGES is smaller in stud diameter than the 32/36 DGEV.
Glenn got a new Weber 38-DGES and is using the O.E. air filter ADAPTOR 99010.600, and rather than drive around and hunt down some smaller diameter studs to fit his new 38-DGES, he is drilling and tapping those holes in the 38-DGES to use his existing bolts that fit the 32/36 DGEV.
Also, he did not get the universal throttle lever with his new 38-DGES and took the one off his 32/36 DGEV and is using that.
Clear as mud...
UPTILLNOW
post #87 of 183 Old 05-20-2013, 01:57 PM Thread Starter
GlennLever
GlennLever's Avatar
I have taken many pictures and will post them.
There are some minor fitment adjustments to get the 38 to bolt on but nothing serious.
Bolted it on and with out any adjustments stalls at stop signs
Seems to rev better, but did not take it up on the expressway to check power above 45
Acceleration is not smooth, seems doggy in lower rpm then bogs down then picks up and goes pretty good.
With out adjustments I seem to have the opposite of what I had, with the 32/36, it was good on the lower end with lots of torque, but dead on the upper end, now with the 38/38 it stalls in the lower end, doggy down low but seems to pick up in the upper end.
I have been properly scolded for not adjusting it before test drive. I'm also powder coating at the moment so tied to the shop. I need to get to the trailer to get the timing light and vacuum gauge.
I will do that shortly, make adjustments as recommended and test drive again.
Glenn R. Lever
My Web Site
post #88 of 183 Old 05-20-2013, 02:13 PM
swatson454
1983 CJ7
Tell Gustavo over at Redline that it's too early in the week for a scolding.
Now where's that fire extinguisher...
Shawn
post #89 of 183 Old 05-20-2013, 07:24 PM Thread Starter
GlennLever
GlennLever's Avatar
I have updated my web site with a full update on this project.
http://www.leverfamilysite.com/1984_...2013_05_20.htm
So this is what we started with, AMC ignition box and computer are gone, MSD box has replaced it with the stock distributor and coil. So basically a stock set up.
This 32/36 was purchased with the the O.E. air filter ADAPTOR 99010.600 so that the stock air filter could be used.
Here they are side by side, note the throttle linkage is different and the 38 has studs for the Weber air filter. Also note the straight mechanical linkage on the 38. The expert that is guiding me installed .50MM Idle Jets, 1.45 MM Main Jets, 1.70 MM Air Corrector Jets, f7 Emulsion tubes, Vitro tip need valve.
Swapping the throttle linkage was very simple as I had followed the instruction when it was installed so it came apart very easily
Next was the studs on the new 38. they had to be removed and the holes drilled and taped to accept the larger bolts for the air filter adapter. Again not a big thing so long as you have the correct metric tap.
The next difference was there is only one vacuum port on the 38 while the 32/36 has two. One is delayed vacuum (not ported) and the other is not and was used for the vacuum to control the functions on the charcoal vapor canister. Again not a big thing I will just pick up the vacuum from the intake manifold for this purpose.
Also note that the fuel inlet on the 38 is on the opposite side of the 32/36. A new fuel line will have to be made up.
Next problem was the bracket for the throttle cable linkage would not sit down on the base because the barrel of the carburetor is bigger. A little grinding solved that problem.
Ok, so I "T" into the vacuum for the air filter to supply vacuum to the charcoal vapor canister, and you can see the new fuel line.
Test drove it with out any adjustments and it stalls at stop signs. Seems to rev better, but did not take it up on the expressway to check power above 45. Acceleration is not smooth, seems doggy in lower rpm then bogs down then picks up and goes pretty good.
I spent some time adjusting.
I found that I could turn the idle speed screw in a 1/4 turn more before the vacuum registered on the delayed port. This allowed me to get the Jeep to idle without having to hold the peddle.
I checked the timing and found that it was at a static 6 degrees, bumped it up to 8 and then had to reduce the idle speed screw by almost a half turn to get the idle down to 500. There is zero vacuum at the delay port and I can screw the idle speed screw out and 1/8 of a turn before vacuum is registered on the gauge. So the idle screw is now 1/8 in before vacuum registers (every expert makes a big point on this).
INTERESTING point, the delayed port only develops 15 pounds of vacuum, while the manifold vacuum is close to 20. I'm wondering if I am getting full vacuum advance with the reduced vacuum for the delay port on the carburetor.
The 38 has adjustable low speed jets (32/36 does not), they were bench set at 1 1/2 turns, with an tachometer I found the "Best Lean Idle" by bracketing the fall off of RPM to be 1 1/4 turns out.
Test drove again, it does not stall, pulls pretty go, but not great, there is a small weak spot at about 1/3 throttle, seems to pull pretty good in the upper RPM 2,000 to 3,000 range. I am out of time and will have to try the highway tomorrow.
When I got back I added an additional 2 degrees in timing, now at 10.
Maybe this will remove the weak spot at 1/3 throttle????
More later.
Questions?
Glenn R. Lever
My Web Site
post #90 of 183 Old 05-20-2013, 11:47 PM
Matt1981CJ7
1981 CJ7
Glenn,
Mine ran best with the distributer hooked to manifold, not ported.
Good luck,
Matt
