Weber - JeepForum.com
post #1 of 183 Old 04-30-2013, 04:23 PM Thread Starter
GlennLever
GlennLever's Avatar
Weber
Before you say it, I have read so much about Weber problems, my brain hurts.
It starts fine, low end up to 45 MPH is really ok.
After that it is dead flat, on a slight incline it loses ground.
I really want to be lazy here as I have more than enough to learn on the mechanical injection on the dragster.
Richer jet? where is it and suggestions on size. how do you change it. Pictures please.
This is a true Weber, purchase as the Jeep "Kit". Everything is stock.
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
post #2 of 183 Old 05-01-2013, 06:03 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Glenn,
Is that the 32/36? If so, my experiences with it were the same as yours, but not as extreme.
The 32/36 is a step down in performance from a good running Carter, IMO. Mine ran silky smooth, and got good gas mileage, but it lacked "giddy up".
The Weber 38 is really the better suited carb for a 258, IMO.
Matt
Matt1981CJ7 is online now
post #3 of 183 Old 05-01-2013, 06:53 AM Thread Starter
GlennLever
GlennLever's Avatar
Originally Posted by Matt1981CJ7 View Post
Glenn,
Matt
Yes it is a 32/36
Really do not want to buy another carburetor.
Based on everything posted it sounds like the secondary jet is to small from the vendor and needs to be replaced. I guess I'm going to have to re rear all the stuff posted on this ans se if I can find that.
Glenn R. Lever
My Web Site
post #4 of 183 Old 05-01-2013, 08:05 AM
swatson454
1983 CJ7
You might try an F7 emulsion tube in the secondary side as well. Those guys really wake up the midrange and help the main circuit activate like it should.
The secondary jet is the one up top on the driver's side. Large, brass screw head below the filter base. It's got a 2 digit number stamped on the end of it.
Hope it helps!
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #5 of 183 Old 05-01-2013, 08:30 AM
sanctified
I'm good to about 55 but figured it dropped off after that due to my 2.7x gears and 32" tires. I am interested in seeing what you find out and whether you can get it to behave like you want it to.
2013 JK (see info on left)
SOLD: 1983 CJ7
Utah Jeep Crew #178
sanctified is offline
post #6 of 183 Old 05-01-2013, 12:14 PM
keith460
Jeep. There's Only One
keith460's Avatar
My Weber 32/36 suffers somewhat of the same fate. Good low end grunt but kinda fizzles out above 3000rpm.
30 over pistons aren't helping either and I will probably go with a 38 DGS Weber this summer or fall. Already have a Pre computer years distributor installed (1979 model) with spring and initial timing tweaked but haven't been able to get the Jeep out of its winter storage yet for driving due to a very busy traveling work schedule.
1984 CJ-7 Renegade
keith460 is online now
post #7 of 183 Old 05-01-2013, 12:18 PM
Balvar24
1979 CJ7
Holy clean engine compartment Batman! Are you sure you've ran that thing long enough to identify a problem? Maybe you just need to burn the new off of it?
"Work hard, rock hard, eat hard, sleep hard, grow big, wear glasses if you need 'em."
Balvar24 is offline
post #8 of 183 Old 05-01-2013, 12:46 PM
Renegade82
1982 CJ7
Ya know Glenn your not helping my feelings of second guessing my choice to buy a Weber K551 (32/36 dgev). In my research I read so much positive stuff on it, sans some tuning qwerks due to fuel pressure. But it seems lately I've been seeing more and more stuff on a negative slant. I never installed it prior to my teardown like I was originally planning to do. I'm just glad theres guys around like swatson454 that seem to have very detailed understanding of Weber carbs and what makes them tick.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #9 of 183 Old 05-01-2013, 01:28 PM
Matt1981CJ7
1981 CJ7
I've never understood why Redline, and others, claim the 32/36 is the best choice for a stock 258, and the 38 is only for modified engines.
Heck, I think they put the 32/36 in cars with engines as small as 2.3L, perhaps smaller.
Matt
post #10 of 183 Old 05-01-2013, 02:31 PM
mwalker649
I don't know anything about em, but I'm having an 85 CJ restored at V3 Jeep shop in Louisville Ky and we just had the Carb talk. They said they prefer the Weber and have through the years of working with them, learned to re-jet and make em work flawlessly. You might give them a call (on web) ask for Rich and he might tell you what they do.
mwalker649 is offline
post #11 of 183 Old 05-01-2013, 04:07 PM
bkeese
1949 CJ3A
Is that the stock air cleaner? I didn't know they would fit a Weber.
1985 CJ7 - total customization underway, Sublime green and Plum crazy purple, Ford 9", 258 w/ Holley 475
1985,93 CJ7,YJ - L98 TPI Vette motor, Atlas twin stick, Dana 60s front and rear, Arbs, 39.5 Swampers
bkeese is offline
post #12 of 183 Old 05-01-2013, 04:38 PM
Matt1981CJ7
1981 CJ7
It requires an adapter, which most Weber dealers will have.
Glenn, I highly recommend you contact Tom at Redline. He's a big Jeep fan, also a member here, and he knows the Webers inside and out. Perhaps he'll work out some sort of exchange deal for a 38...it's worth asking.
Either way, I'm sure he'll offer good advice, and he will have the necessary little parts, if you decide to re-jet the 32/36.
Matt
post #13 of 183 Old 05-02-2013, 05:59 AM
bkeese
1949 CJ3A
How does the 32/36 work with the AMC 150 4 banger?
bkeese is offline
post #14 of 183 Old 05-02-2013, 06:02 AM
swatson454
1983 CJ7
Probably just about perfect, assuming you have a 2-barrel manifold.
Shawn
post #15 of 183 Old 05-05-2013, 11:36 AM Thread Starter
GlennLever
GlennLever's Avatar
Hope it helps!
Shawn
I have fallen behind here, sorry, what is an "F7 emulsion tube"
I will pull the secondary jet today and take a look, what size do you think it should be? larger than what is there?
Glenn R. Lever
My Web Site
