Which way does the coolant flow???? - JeepForum.com
post #1 of 4 Old 08-25-2013, 02:42 PM Thread Starter
twill145
1977 DJ
I have a 1967 CJ-5 with the Buick Dauntless V-6 engine. I am doing some work on the cooling system and cant figure out which way the coolant flows? Does it flow from the bottom radiator hose into the engine then out the top hose back into the radiator or visa versa? Please help!!
Thanks!
twill145 is offline
post #2 of 4 Old 08-25-2013, 03:03 PM
Texian
1978 CJ7
Yes,you got it correct.
Cooler water comes from the bottom of the radiator to the engine.
Hot water flows into radiator from the top from the engine.
Texian is offline
post #3 of 4 Old 08-25-2013, 06:23 PM
LumpyGrits
YUP, from the bottom via the engine, then to the top of the radiator inlet.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #4 of 4 Old 08-25-2013, 08:46 PM
BagusJeep
1981 CJ7
Yup, otherwise you would be sucking air half the time.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
cj5 , coolant flow , dauntless
