waterproof question - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > waterproof question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineHMF Fabrication 50" Light Bar Mounts for CJ/YJ Made IDISCOUNT LOCKER and AXLE SHAFT Days Sales at Baseline 4x4
Unread 05-15-2006, 09:06 PM   #1
cheapjeepman
waterproof question
hey,
ok this is my first real all the time offroad jeep. I am trying to find out how bad driving through really deep water (like over the hood) is for everything. I have 38's and lift and all the goodies to fit those, and of course a snorkel, and waterproof wiring.
Thanks,
Chris
cheapjeepman is offline   Reply With Quote
Unread 05-15-2006, 09:44 PM   #2
gosupes
Anything over the hood for an extended period of time can be problems. Other parts of the engine are not protected. You can pull a fan blade in the radiator, the alternator isn't protected, all the breather tubes are below the water line, etc. Not to mention that if you ingest water into the engine, you can hydro-lock it and do some serious damage. All that said, it will take some extra maintenance with special attention to the drivetrain in general.
1986 CJ7, 4.2 w/4.0 head, TFI-HEI hybrid ignition, Clifford manifold w/Holley 390 w/cold air intake, OBA (in work), 150 amp alt., 4.5" lift, Woody CV shaft, 4.10 gears - lunchbox in front, Truetrac in the back, twin-sticked, blower upgrade for running topless, keepin' it simple.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline   Reply With Quote
Unread 05-15-2006, 10:53 PM   #3
John N
1981 CJ8
It's a Jeep, not a submarine. Be sure you change the oil in the diffs, transmission and transfer case and repack the wheel bearing after every swim.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline   Reply With Quote
Unread 05-16-2006, 02:31 AM   #4
GPER
1979 CJ7
If your going that deep you might want to something like this, but tap it inti your snorkel.
http://www.websitetoolbox.com/tool/p...post?id=836809
GPER is offline   Reply With Quote
