washer sprayer thing on hood - JeepForum.com
post #1 of 12 Old 02-18-2010, 07:40 PM Thread Starter
1BigPig
1977 CJ7
Whats the name of the washer sprayer nozzle thing that sits on top of the hood and is where the wiper fluid comes out? And where's the cheapest place to buy one? I replaced my wiper washer pump tonight and the driver's side of the nozzle was clogged. I took a flathead screw driver to it and the end broke off.
1BigPig is offline
post #2 of 12 Old 02-18-2010, 08:33 PM
wm69
Jeep CJ, CJ5, CJ7, CJ8 Wiper Spray Nozzle : eBay Motors (item 220556811763 end time Feb-21-10 18:53:51 PST)
wm69 is offline
post #3 of 12 Old 02-18-2010, 08:47 PM
TDHofstetter
As to the jargon... it's officially known as a "washer sprayer nozzle thing that sits on top of the hood".
TDHofstetter is offline
post #4 of 12 Old 02-19-2010, 07:23 AM
CJ Chet
I used a pair from a TJ. Very easy to install (drill hole, pop in), cheap, and they work better.
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #5 of 12 Old 02-19-2010, 08:34 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I often thought of changing my "washer sprayer nozzle thing that sits on top of the hood" to the TJ version and get a couple of the original "washer sprayer nozzle thing that sits on top of the hood" to clean the salt off my headlights in winter.
John Strenk is offline
post #6 of 12 Old 02-19-2010, 09:47 AM
CJ Chet
Excellent idea! I might look into that myself.
'86 CJ7
'04 AEV RUBICON
CJ Chet is offline
post #7 of 12 Old 02-19-2010, 09:54 AM
cincyjeeprs
Now you are on to something. Maybe add a pair of those headlight wipers from a Mercedes - oh, wait - those might not work on our frog-eyed sealed beams.
cincyjeeprs is offline
post #8 of 12 Old 02-19-2010, 10:50 AM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
I have a factory CJ "washer nozzle assembly that sits on the cowl" available. (Same parts shown in the evilBay link above.) PM me if interested.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #9 of 12 Old 02-19-2010, 02:37 PM
Redmanchew
Redmanchew's Avatar
1982 CJ7
I like the TJ idea since the drives side of my "washer sprayer nozzle thing that sits on top of the hood" kinda hits the car next to me and is unadjustable anymore...
sorry much like everyone else i could not resist using "washer sprayer nozzle thing that sits on top of the hood" in a technical post.
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #10 of 12 Old 02-19-2010, 03:44 PM
IdahoJeeper
Hey Chet....great idea!! I'm wondering if you can provide some dimensions where you put 'em or did you use a "trail-n-error" method like hooking up the fluid line and ballparking where the spray worked best?
I picked up all the parts @ Checker for $20 and now have a project for Saturday!
'95 ZJ Laredo, 4.0L, Auto, 225K, Forest Grn
'98 ZJ Laredo, 4.0L, Auto, 210K, White
IdahoJeeper is offline
post #11 of 12 Old 02-19-2010, 05:00 PM
CJ Chet
I just winged it! You do have to watch out for the reinforcing channels under the hood. If you get inside one of them you won't be able to get the water line to it. BTW, you'll need to run new water lines. Here are a couple photos:
'86 CJ7
'04 AEV RUBICON
CJ Chet is offline
post #12 of 12 Old 02-19-2010, 05:31 PM
gotCLAY
I put a set of ford van nozzles that go on the wiper arms. They spay right in front of the wiper with a wide spray pattern that cover the hole window in one pass.
GOOD LUCK & GOD BLESS
gotCLAY is offline
Looking for Thrust Washer... poppatello Jeep CJ Forum 0 12-09-2009 04:50 AM
Pitman Arm Washer Rupie25 Jeep CJ Forum 5 10-22-2009 08:55 PM
lock washer ? lucdog Jeep CJ Forum 1 03-25-2009 12:49 AM
Windshield Washer kit chet44 Jeep CJ Forum 6 12-04-2008 11:53 AM
windshield washer haustow Jeep CJ Forum 2 02-01-2006 08:36 AM
