Warn Premium Hub Bearing - JeepForum.com
post #1 of 8 Old 05-27-2015, 11:53 AM Thread Starter
Stumpfarming
1974 CJ5
Anyone know where I can get a replacement bearing for a Warn Premium Hub from a 72'-75' CJ? I spent the better part of the last hour or so at the local 4X4 shop (which can usually come up with just about anything). The original part is a Torrington Y-246, which I learned was later changed to B246. I believe it was discontinued in 1996. We managed to find a cross-reference number to a Massey-Ferguson tractor, but ran into a dead end at that point. I hate to swap out the entire hub just because I can't find a bearing.
http://www.jeepforum.com/forum/f22/stumpfarmings-73-cj5-build-1935041/
Stumpfarming is offline
post #2 of 8 Old 05-27-2015, 12:10 PM
firegod33
1977 CJ5
A locking hub doesn't have bearings. Are you referring to the wheel bearings?
Earth first... We'll Jeep the other planets later.
firegod33 is offline
post #3 of 8 Old 05-27-2015, 12:19 PM
1949er
Only Torrington bearing I can think of in a 30 is in the Spindle for the outer axle
1949er is offline
post #4 of 8 Old 05-27-2015, 12:22 PM
firegod33
1977 CJ5
Does it look like these?
http://www.autozone.com/drivetrain/a...mString=search
post #5 of 8 Old 05-27-2015, 01:15 PM
Fourtrail
1974 CJ6
According to this thread, Herm the overdrive guy had replacement bearings 3 years ago. Might still have some or a part number that will cross.
http://hermtheoverdriveguy.com/
http://www.earlycj5.net/forums/showt...m-79-CJ7/page2
Edit: Looks like they are listed on his site in a rebuild kit.
http://hermtheoverdriveguy.com/?page_id=1569
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #6 of 8 Old 05-27-2015, 01:51 PM Thread Starter
Stumpfarming
1974 CJ5
Yes, I think that is it! I'll check with Herm.
post #7 of 8 Old 05-27-2015, 01:57 PM Thread Starter
Stumpfarming
1974 CJ5
I am referring to the bearing shown in this picture, part of the "selectable drive hub" shown under "special equipment" in the 1974 FSM.
post #8 of 8 Old 05-27-2015, 02:40 PM Thread Starter
Stumpfarming
1974 CJ5
I spoke with Herm a few minutes ago. He confirmed that the bearing has been discontinued. He said that Warn has come up with a nylon washer as a replacement for the bearing. I'll probably order a whole rebuild kit from him (as shown above) with the nylon washer instead of the bearing.
