Warn overdrive with dana 18 - JeepForum.com
post #1 of 12 Old 05-05-2013, 08:19 PM Thread Starter
Beau_54
1970 CJ7
So I bought an overdrive with matching planetary gear for my dana 18. Got everything installed except the overdrive. My ******* starts to put it on and bam ****er won't work. Didn't realize that a front shift overdrive doesn't bolt up. So what the **** does this overdrive work with? Maybe an early dana 18
Beau_54 is offline
post #2 of 12 Old 05-05-2013, 11:17 PM
1986cj
it is a Warn? What is a front shift overdrive? AA holds the patten for it now, sold under the Saturn name. What don't fit? There is a company called Hrem? the overdrive guy ( I think) that sells and knows a lot about the Warn overdrive. I know there is a 33 and a 29 tooth gear and they have to match and there is a small hole and a large hole case. I had a couple of them back in the early 70s but both of mine were 47 18s in Jeep CJ2As.
1986cj is offline
post #3 of 12 Old 05-05-2013, 11:30 PM Thread Starter
Beau_54
1970 CJ7
It's a warn 33-29
Beau_54 is offline
post #4 of 12 Old 05-05-2013, 11:32 PM Thread Starter
Beau_54
1970 CJ7
Front shift means the shift engagement lever is to the front of the unit
Beau_54 is offline
post #5 of 12 Old 05-05-2013, 11:40 PM
1986cj
Check out advanced adaptors web sight they show how to tell a small hole case from a large hole case.
1986cj is offline
post #6 of 12 Old 05-05-2013, 11:48 PM
1986cj
This is a good read for some info on them http://www.willysjeepparts.com/Overdrive.htm
1986cj is offline
post #7 of 12 Old 05-06-2013, 08:49 PM Thread Starter
Beau_54
1970 CJ7
Ok screw this od. Anyone want to buy it or trade
Beau_54 is offline
post #8 of 12 Old 06-19-2013, 02:12 PM
LLYJ
Hi - I would be interested in buying or trading
How much $ do you want for it
Is it rebuilt, tested ? What do you want in trade ?
LLYJ is offline
post #9 of 12 Old 06-20-2013, 11:38 AM
duffer
1955 CJ3B
I didn't know Warn even made a front shift option on the 33-29. I thought the front shift was only with the very early models like a 20-29. A front shift, as noted, will not work with the 4" index late D18 or D20 housings.
Best place for OD info is Herm's site
http://hermtheoverdriveguy.com/
Herm Tillford is extremely knowledgeable and will take the time to talk to you and is ameanable to trading parts.
Besides, he has a nice looking 3B on the header
I see no information on exactly what you are working on but if your Jeep has the V6 (only ones that used the large index T case) and the optional 4.88 gears, it is the absolute best improvement you can make.
1955 CJ 3B, 381cid sbc (441cid all aluminum sbc coming soon), AGE M22W, Teralows, Warn OD, OBA, Premier Power welder, Warn 8274
1968 CJ 5, factory 225" w/ headers/450 cfm Holley, T86AA, Belleview winch, Warn OD
2012 Wrangler Rubicon Unlimited, Warn 9.5 xp-s winch
duffer is offline
post #10 of 12 Old 06-22-2013, 07:54 PM Thread Starter
Beau_54
1970 CJ7
Changing concepts i just got 2 dana 44 axles from a scout with disc brakes all around. Willing to trade dana 18 and a warn overdrive for lockers. Also got 2 axles with 4.88
Beau_54 is offline
post #11 of 12 Old 06-25-2013, 09:19 PM
LLYJ
That will work on my 51 CJ3A (V6 SM420)
Don't have lockers, how much $ do you want ?
Thanks
LLYJ is offline
post #12 of 12 Old 06-30-2013, 12:42 AM Thread Starter
Beau_54
1970 CJ7
If ur in Alberta it would cost a fortune to ship axles but the overdrive would be reasonable. The axles are a dana 44 rear and 27 front. Chromoly axle shafts 4.88 gears with lockers.
Beau_54 is offline
dana 20 , overdrive
