Warn Manual Locking Hubs - Newbie Needs Help
| Truck-Lite's New LED Headlamp Series | TJ 5.25" Speaker Adapters - NalinMFG | CURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee! |
#1 | |
I've just replaced the front wheel bearings and seals on my 1980 CJ7, and I went back with the Warn Premium Manual Locking Hubs as an upgrade to the stock hubs. Everything went pretty well, except having a bunch of parts left over
!So the install now includes: inner seal, inner bearing, inner race, outer race, outer bearing, wheel washer 1, wheel nut 1, wheel washer 2, wheel nut 2, axle snap ring, Warn hub base, Warn hub lock. Was any of the rest of the stock stuff like the spring, brass bushing, hub clutch, outer snap ring, gear, supposed to be shoved in there somewhere? ![]() I ask, because the new hubs don't seem to disengage from the axle, regardless of the position of the lock (4 X 2 or 4 X 4) Thanks in advance for your patience, and I would very much appreciate any advice...
#2 |
I'm not sure about what all the Warn hubs include, but you may want to check to make sure you didn't pack way too much grease in there. I went crazy packing grease into my hubs and they were sticking as well and not immediately unlocking. After cleaning some excess out it was alrighty.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress) 1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress) |
#3 |
I did smoodge up the spline a little, to be sure there was no metal to metal wear, so maybe I went overboard! Thanks, I'll check it out...
#4 |
Im pretty sure you only need the 2 washers and 2 lock nuts. for the axle..The rest should be included with the warn hubs..Whatever they included in the package..I dont see you having to reuse any parts of the stock lock outs..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1 1984 cj8 350 on 35's..the wifes [QUOTE=Me] "offroad it, and wave then you might understand"[/QUOTE] BLS Home Chapter... Where it all Started :hahaha: yj My low Buck Rock Crawler project Project..Stop by and check it out..[URL="http://www.jeepforum.com/forum/showthread.php?t=497896"][B][COLOR="DarkOrange"]The lizzard Queen[/COLOR][/B][/URL] |
#5 |
Check and make sure you did not tighten down the inner nuts to tight. If you jack the front tire up you should be able to spin it easy. If it's to tight it will keep it from unlocking.
Should only be a 2 washers and 2 nuts. Also recheck the spring right behind the hub face to make sure it isn't bound up. |
#6 |
Thanks, Fellas'!
I went back and checked each wheel, raising one at a time (like the instructions said), and they seem to be fine now. Maybe just a little tight at first... The bearing nuts were installed just like the manual recommends, 50 ft. pounds, then backed off 45 degrees. I have to tell you that I find the bending of the outside washer over the nut a strange design. But I reckon' it works, and without having to have too special of a washer or nut set! My only other experience with 4X4's was years back when I had an old Bronco. It had the special nut with the small pin on the side, the multi-holed tabbed washer washer, etc.... Anyway, thanks again for the help, and I'm just learning as I go!
1980 CJ7, AMC 360, 2.5" Lift, 33 X 12.5 Cepek FCII's on 16 X 10 MT Classic II's |
#7 | |
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
The outer snap ring holds/held the gear on the axle right? What holds the new gear on there now? I ask because the ring in the outer case moves outward to unlock the hubs. If the axle gear isn't held in with the outer snap ring, it will just lift up with the outer ring I would think. I bought just the outer half of the warn hub and used all my CJ stuff on the axle half.
Mike 86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10) |
#8 |
I did get the new hubs in a sealed box, so I'm fairly positive that all required parts were there.
And I guess your questioning of the snap rings is the one that still has me thinkin'! The outer snap ring is NOT installed, as it seems to me that the new hub has everything included, like the gear and such. The inner snap ring, which is under the hub base and installed just where the axle emerges from the spindle IS installed, to keep the axle where it needs to be. To this newbie, engagement occurs when the hub gear washers (teeth on the outside, looks like a big star washer) is pushed IN to "grab" the I.D. of the hub base, thus locking all components together. With all this, is seems to me that the outer snap ring would just be in the way and foul up the works. Like I said, based on the tests in the instructions, and after rotating them a bit, all seems to be functioning properly! I'll be sure to post back if (when?) that changes. Thanks Again!
#9 | |
Off Road Forever
I believe the snap rings are 'axle' parts, not necessarily hub parts, but could be way off. Anyhow, my warn hub needs the outer snap ring to work with the Jeep hub's inner gear or at least it does work quite well with it in place.
#10 |
And the final answer is, and in order of assembly...
Inner seal, inner bearing, inner race, outer race, outer bearing, wheel washer 1, wheel nut 1, wheel washer 2, wheel nut 2, Warn hub base, axle snap ring, Warn hub lock. Hopefully, this will help some other newb along the way! Mike, you were absolutely correct! Thanks to you, everyone else, and Aaron Hall at Warn Customer Service for their contribution!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
