Quantcast Warn Hubs -manual or "Automatic"? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Warn Hubs -manual or "Automatic"?
Free Shipping on TIRES at KrawlOff-RoadSpartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase Required
Old 06-20-2008, 04:29 PM   #1
4d9r
1975 CJ5
My '75 cj5 doesn't have locking hubs (their always engaged).
Found a new set of "automatic", automatic engage when transfer case is shifted into 4wd, shift back to 2wd and back up couple feet to disengage. Do these work or should I get a set of the regular warn hubs?
4d9r is offline   Reply With Quote
Old 06-20-2008, 04:38 PM   #2
JoonHoss
1968 C101
umm, are you sure they are for your application? those are how the hubs work on vacuum or electric controls (YJ's and TJ's), but not usually manual (CJ's)???
Hoss
It's hard to say no to yoo-hoo, the name literally beckons...
Don't mind me, I'm just another FNG around here...
JoonHoss is offline   Reply With Quote
Old 06-20-2008, 04:48 PM   #3
jeepdaddy2000
1971 CJ5
Automatic hubs for external applications are somewhat rare. The IH crowd sees them from time to time as they were a somewhat popular accessory. While they work well they are obsolete and parts are becoming hard to find. I would doubt you are looking at a new set. If you are seeing a used set and decide to buy, insure you get the wheel bearing nuts as well, since they are organic to the hubs.
jeepdaddy2000 is offline   Reply With Quote
Old 06-20-2008, 05:00 PM   #4
Smtty58
I had a set once on a 1 ton Chevy. Factory says to disassemble the entire hub (requires a special tool) and lube every 2500 miles! This got old fast, and I stopped doing it. Wasn't long before they stopped working, and with no manual overide you're stuck with two wheel drive. These were the factory hubs, not sure who made them for GM.
90 YJ, 4.2, AX-15
86 K1500, 305, 700R4
Western Mass. 4x4
Smtty58 is offline   Reply With Quote
Old 06-21-2008, 10:12 AM   #5
diamatron
1978 CJ7
My Ranger used to have some Warn automatic hubs. I hated then. Getting them to unlock and engage was a mystery sometimes. They worked good for the first 60k l=miles i guess. I instaeed Manual hubs now.
diamatron is offline   Reply With Quote
Old 06-21-2008, 10:29 AM   #6
No_Bs
1977 CJ5
Yeah, I used to have these on my F150 and they were a pain. Half the time they wouldn't engage until I was spinning, and caused a serious drivetrain shock when they did. Go with true manuals, you'll be much happier.
1977 Cj5, 258, T-18, 2.46:1 Dana 20, 2.5" BDS lift, OBA, 38.5's. Chevy 60 frt, 14b Rear, Full hydro, 102"wb, full DOM cage.
No_Bs is offline   Reply With Quote
Old 06-22-2008, 09:06 AM   #7
4d9r
1975 CJ5
Manual they shall be. Thanks guys.....
Old 06-22-2008, 02:57 PM   #8
OldSailor
1977 CJ7
I yoiu do much serious off-roading, I'd avoid automatic hubs. They are very likely to unlock on you when you backup offroad. Depending on the type of terrain (e.g., rocks) you're on, that can be disasterous.
1977 CJ7, AMC360 V8 w/ headers, DUI HEI, Edelbrock intake, Holley 4150 carb, , TF999, D300, D30 front and AMC20 rear with 4.56 gears and lockers both ends, 4" susp lift, 2.5" body lift, 35" BFGs, ARG steering, 8000-lb winch, etc.
OldSailor is offline   Reply With Quote
Old 06-23-2008, 03:57 PM   #9
jeepdaddy2000
1971 CJ5
Understand guys, that external Warn automatic hubs differ in operation. They use a jam roller design. They also have a manual lock that bypasses the auto lock feature giving you a true locking hub. As for internal auto's. Virtually the problem units that I have seen, the malfunction has been caused by either hard grease or rust(IE lack of service).
Glock Forum
