Warn 8274 rebuild - JeepForum.com
post #1 of 102 Old 03-23-2010, 08:54 AM Thread Starter
wm69
Warn 8274 rebuild
I found a couple of pretty in depth rebuilds on the net (one on pirate, other on ih8mud) but neither addressed my problem.
I picked up a Jeep Special Equipment 8274 late last week. It was on the front of a 76 Waggy and I bought the whole thing. Not sure what I'm going to do with the Waggy, but the guy didn't want to sell the winch separately.
Anyhow, serial number is 12XXX, so looks like an early one.
Solenoid cover was gone, solenoids are trashed, motor is going to be rebuilt locally just to be on the safe side. Needs a controller. I'll end up with quite a bit in it just in parts, but I figure it will be worth it to have a completely rebuild old Warn. Gears look good.
The drum is seized. I soaked it with PB blaster and managed to get the non-motor end off, and the drum will now turn with some effort, but it needs a lower bushing kit and I need to get it apart and smooth everything up. The end that meshes with the gears is really on there. I don't want to get too nasty with it and crack the lower gear housing. I have not removed the brake yet (waiting on Dad to find his monster sized snap ring pliers) so still have to do that, but from what I've seen, the drum is just pushed up into the housing and held in place by a lock plate. I have the plate pulled up, and I cannot get this thing to budge.
Am I missing something or does anyone have any suggestions as to how to break it loose?
wm69 is offline
post #2 of 102 Old 03-23-2010, 11:37 AM
JeepnBlake
Heat might help.
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #3 of 102 Old 03-23-2010, 01:32 PM
RARECJ8
RARECJ8's Avatar
1981 CJ8
The BillaVista rebuild article is the very best. If not, maybe a gentle application of the BFH?
mb
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #4 of 102 Old 03-23-2010, 02:16 PM Thread Starter
wm69
mb
Been banging on it with a rubber mallet. Scared I'm going to crack the housing. I think I might try removing the brake and shaft and associated parts and then see if I can't get a better shot at getting some penetrating oil down where the gears mesh.
Want to put a new lower kit in it before I put it back together. Brake seems to be frozen anyway, so gotta get that off and redo it too.
wm69 is offline
post #5 of 102 Old 03-24-2010, 02:28 AM
pazur
1981 CJ7
You can remove brake without taking it apart. It is held only with the same locking plate and brass bushing. Just hit the shaft from inside with some hard wood prick (some recommend brass - IMO not necessary). Brake is much tougher to take apart than drum, so don't mess up with it unless you want to replace pads.
pazur is offline
post #6 of 102 Old 03-25-2010, 06:09 AM
GPER
1979 CJ7
Most likely your brake has not been rebuilt since it was new. Therefor it is of the old design and should be rebuilt with the new parts, it isn't that hard to do.
GPER is offline
post #7 of 102 Old 03-25-2010, 09:31 PM Thread Starter
wm69
Got the brake off. Ended up putting a 2x4 on the inner part of the housing and hammering it off. Haven't taken it apart yet but will put a kit in it before I put it back on.
Drum is seized, so it needs to come off, new bushings put in, smoothed up before reinstallation.
Moved it a littel bit today. Will get it off with PB blaster, a propane torch, and a rubber mallet. Might take me 10 years, but that SOB is coming off.....
wm69 is offline
post #8 of 102 Old 03-25-2010, 10:52 PM
Trapshooter
I just rebuilt a 1979, 8274 this summer following the pirate 4x4 instructions that you noted. After pulling the lock plate as per item # 37 of the pirate instructions the drum separated from the housing.
Looking down from the top of the gear housing you should be able to see where the large reduction gear meshes with the drum end gear. Are the gears totally corroded?
I am going to ask a dumb question....the lock plate is completely inverted as in item # 40 of the pirate 4x4 instructions.
I have many of the part numbers for the busing kits, solenoid cover, etc. in my files, unfortunately I am on the road and won't be home until late tomorrow night. Let me know if you need those part numbers and I'll get them posted on Saturday.
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #9 of 102 Old 03-26-2010, 03:22 AM
pazur
1981 CJ7
The locking plate goes there one way; #40 picture does not show it in locked position. Its upper side must be level with the lowe case mating surface. If the plate is e.g. 1 mm higher the drum is not locked.
Make photos as you take the winch apart. Pirate bay guide e.g. does not show how you place the brake transmission gear, how you assemble brake. Be careful not to put too much grease inside brake. You don't have to replace pads if they are 30 years old. Winches are usually used for pulling out of mud, thus brake does not wear fast. In my 8274 OE pads were like new.
Some folks suggest to replace the brake retainer ring with bolt and they claim they threaded brake shaft. Don't try to drill into the shaft. Is is a hardened still and regular HSS, plated with platinum or whatever drill has no chance to bite into this. You would need carbide tools. short 3/16 drill costs $10.
pazur is offline
post #10 of 102 Old 03-26-2010, 07:10 AM
halpeters
1978 CJ7
Check out the WARN site:
Warn Industries - Replacement Parts
They have many parts for the older units, and parts schematics on line...
Hal
1978 CJ-7
halpeters is offline
post #11 of 102 Old 03-26-2010, 07:14 AM
Chris98TJ
warnserviceparts.com has the cheapest parts that ive found when i rebuilt mine
98 tj sport Aussie locked front and rear 4.10's HPD30 8.8 super short sye cv shaft 4.5 lift johnny joint adj. control arms 36in TSL's gen right hi fenders header exhaust custom rockers Solid axle covers f/r the list goes on
Leading bullet sponge for JF Call of Duty crew
X BOX GT- CHRIS98TJ
Chris98TJ is offline
post #12 of 102 Old 03-26-2010, 09:39 AM Thread Starter
wm69
Yeah, when I got the brake shaft out the lock plate was released and came out, so it's off the housing.
Pretty sure the drum and reduction gear are just rusted together. I've been soaking with PB blaster and it's moved a little bit. I'm banging on it with a rubber mallet because I'm scared I'll break the lower gear housing. It's slowly separating, so I'll just keep banging on it, soaking, banging, soaking. I think it helped a lot after I got the brake shaft out of the way so I can sit the winch up and let the penetrating oil sit in the hub of the gear where it meshes with the drum. Hopefully I'll get it off this weekend.
I've got most of the parts I need. I'm retaining the old style solenoids and am going to use golf cart solenoids from DB Electric so I can replace them easily and cheaply. Got an aluminum copy of a solenoid cover that I found while searching (looks almost exactly like the original plastic cover but is aluminum) and I'm going to replace lower bushings, brake innards, new remote and socket, and put some zerks on the end cap to grease the free end of the drum easily. Still have to get my motor rebuilt by local guys. Also found a reproduction Jeep Special Equipment sticker that looks like the original one, so when I get it put back together it's gonna look awesome.
Probably be a long process, but I've almost got the thing apart where I can get it cleaned up. The Jeep it came off of has been parked for 15 years, and I'm guessing the winch was rarely used, so it might not have been used for 20+ years.
wm69 is offline
post #13 of 102 Old 03-26-2010, 09:43 AM Thread Starter
wm69
When I got the brake shaft (brake assembly is still on the shaft, got to find some snap ring pliers) off the ring spins freely around the housing sides. I can hear the ball bearings in there so they are free. How exactly does this thing work? (what engages the pads?)
wm69 is offline
post #14 of 102 Old 03-29-2010, 06:41 AM
pazur
1981 CJ7
It is the shaft itself that expands as you twist it to one side (braking). closer examine it if you have it off the winch. The balls inside brake assembly: IMO a sealed bearing would work much nicer but Warn designed it this way. Their condition affects only braking. Not winching.
pazur is offline
post #15 of 102 Old 03-29-2010, 09:26 AM Thread Starter
wm69
Thanks for the reply. I'm going to take it apart and have a look at it. Would be nice if everything looked ok, but given the condition of the rest of the winch I'm planning on having to rebuild the brake as well.
wm69 is offline
wiring up a warn 8274 dayriesw Jeep CJ Forum 6 12-15-2009 10:32 AM
WARN 8274 on a 3" Tube bumper? Oregon76CJ7 Jeep CJ Forum 6 02-13-2009 05:45 PM
8274 Winch Plate Help... poppatello Jeep CJ Forum 5 02-08-2009 11:50 AM
8274 warn winch jeep special equipment stumpman Jeep CJ Forum 2 12-17-2008 09:33 AM
warn winch 8274 sierra1boy Jeep CJ Forum 7 01-05-2006 07:28 AM
