WANTED F&R 44's for a CJ - JeepForum.com
post #1 of 10 Old 05-21-2013, 07:05 AM Thread Starter
ksk1480
Looking for a pair of Dana 44's for a late 70's/early 80's CJ7 to replace the model 20 and 30. Must be 5 lug and same width as the 20 & 30.
Rear 20 measurements are:
51" flange to flange and 36" Spring Centers
Front 30 imeasurements are:
51" knuckle to knuckle and 27 3/4" spring centers
Call Kris at 484-955-8571
Thanks for looking.
ksk1480 is offline
post #2 of 10 Old 05-21-2013, 07:24 AM
CSP
Unless you find someone who's modified 44s to the specs you've listed already, or you pony up for someone to modifiy some for you it aint gonna happen.
There's also a wanted section in the classifieds.
CSP is offline
post #3 of 10 Old 05-21-2013, 07:24 AM
kickingprop
www.dynatrac.com
www.samsoffroad.com
Get your pocketbook warmed up. You wont find 44's ready to bolt into a CJ anywhere else.
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is offline
post #4 of 10 Old 05-21-2013, 08:11 AM
duffer
1955 CJ3B
Yep, no stock D44 CJ front axles. A centered, flanged, 30 spline narrow track D44 from a 72-75 should be a near bolt-in in the rear. These are sort of rare and may take some time to find, but are out there. They were the best rear axle that Jeep used in a CJ.
For the front, if you want the stock width D44, it will be a custom axle. There are a number of ways to get there, but none will be cheap.
1955 CJ 3B, 381cid sbc (441cid all aluminum sbc coming soon), AGE M22W, Teralows, Warn OD, OBA, Premier Power welder, Warn 8274
1968 CJ 5, factory 225" w/ headers/450 cfm Holley, T86AA, Belleview winch, Warn OD
2012 Wrangler Rubicon Unlimited, Warn 9.5 xp-s winch
duffer is offline
post #5 of 10 Old 05-21-2013, 10:42 AM Thread Starter
ksk1480
Ok thank you very much guys. Figured that would be the issue with the front, but never know if someone is taking one out to upgrade to a 60. Thanks for the help guys!
ksk1480 is offline
post #6 of 10 Old 05-21-2013, 07:50 PM
gojeepgo
1981 CJ7
The rear 44 found in 72-75 CJ's is not bolt in to the 76's and on. The spring perches will need to be moved. They are also slightly narrower than a narrow track CJ rear end. Still a good option if you can find one.
gojeepgo is offline
post #7 of 10 Old 05-21-2013, 08:08 PM
CSP
This is incorrect. The 72-75 CJ D44 is the same width as the narrow track AMC 20 at 50.5" from wheel mount surface to wheel mount surface.
The D44 found in '73 and older Commandos with the Dana 20 area bolt in for '76 and up CJs as the spring pad spacing is the same at 36" on center.
CSP is offline
post #8 of 10 Old 05-24-2013, 06:52 AM Thread Starter
ksk1480
Thanks guys, may have found a rear here locally out of a buddies junk Commando. May just upgrade the front with a good carrier and axles. FOund a good deal on a bolt in 60 here locally but that would be overkill for this thing.
ksk1480 is offline
post #9 of 10 Old 05-24-2013, 07:16 AM
bsmsmd
Not sure where you are located but I just swapped out my wide track 44 out of my 86. It has 3.73 and an Aussie locker. It is setup for soa but that is easy enought to fix.
bsmsmd is offline
post #10 of 10 Old 05-24-2013, 07:47 AM
CSP
Just make sure that it's a Dana 44. Depending on the year, some of them actually had a Dana 30 rear axle.
CSP is offline
