Want some input on gearing - JeepForum.com
post #1 of 9 Old 01-20-2010, 09:16 AM Thread Starter
greeninwyo
Hey guys,
I just got all my wire problems in the dash fixed and blinkers working and all new brake parts coming the end of the week. So after that its gear time. It is a 75 CJ5 with 30 front and 44 rear with 3.73, 3 speed, 304, 33" tires and stock transfer. Last year in low, low was way to fast on the mountain so I want to change gears and was looking at 4.11 to 4.88. Its a summer toy so just around town and to the mountain and dont care about top end, 60 would be plenty for top end. And please no suggestions of swapping trans or new atlas or axles, so on and so on. Thanks for any input
greeninwyo is offline
post #2 of 9 Old 01-20-2010, 09:20 AM
JoonHoss
2011 JK Wrangler
IF you don't care about top end, 4.88's would definitely get you plenty of low end, however, if it were up to me, I'd go with 4.56's unless you plan on going to 35's at some point. 4.11's is almost too small of a change to be worthwhile, IMHO.
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is online now
post #3 of 9 Old 01-20-2010, 10:12 AM Thread Starter
greeninwyo
Ya I thought of 4.56 too and like I said I have to drive it to the mountain so wasnt real sure of the top end on 4.88
thanks
post #4 of 9 Old 01-20-2010, 10:19 AM
CSP
Another option is try to find another '72-75 with 4.27 gearing. My '75 had 3.73's also and I found a pair of axles from a '72 that I swapped in with 4.27s (optional ratio in '72-75). I found them to be about perfect for 33s.
Use this link to determine what your RPM's would be with different ratios.
Gear Ratio Calculator
CSP is offline
post #5 of 9 Old 01-20-2010, 01:04 PM Thread Starter
greeninwyo
OK thanks CSP might be hard to find in wyoming but Ill check around
post #6 of 9 Old 01-21-2010, 06:54 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
for the cost of gears, you could do a T18/SM/NP transmission swap. This would net you much stronger transmission, the crawl rate your looking for, and retain your ability to drive the Jeep on the road.
You could also look at a transfercase reduction set.
Just some options.....
jeepdaddy2000 is offline
post #7 of 9 Old 01-21-2010, 08:01 AM
Fjguercio
1978 CJ7
I am kinda in the same boat... I have a 3 speed road with granny gear... a T18 with 3.54 stock gears and 33x12.5 tires. The road for me is fast but mpg is good if I feather the gas with a vac gauge. The granny allows me to do the mild type of off road nice. I am changing to 3.73s from 1974. If not for the granny I would be doing the 4.09, 4.10, or up to 4.56. Hwy cruise is 2400/2500 now and do not want to change a lot.
I like the idea of changes to transfer gear case mentioned above... that would be the easiest change and net the results you have the issue with, too fast off road... but its 2:1 stock changes to 2.46:1 and 3.15:1 in low are avail
The other thing... If you have a really nice CJ same to start changing it up a lot??
Here is a gearing calculator that does side by side compair and has all the trans ratios per gear and Transfer Case.
Great Calculator and side x side comparison
http://www.grimmjeeper.com/gears.html
Fjguercio is offline
post #8 of 9 Old 01-21-2010, 11:26 AM
80cj
80cj's Avatar
1980 CJ5
greeninwyo,
I can relate to what you're saying. I had a 76 CJ-5 with 304, 3 speed T-150, D20 T/C and 3.54 's with 32's. What a lousy combination. It was a good highway and beach Jeep--forget the mountains. I sold it for my present 80 CJ-5. Your 3.73's are OK with 33's and make for good highway gears. In your situation, I would look for a T-18 with 6.32 gears although the quickest solution would be a transfer case gear swap.
80cj is offline
post #9 of 9 Old 01-22-2010, 08:15 AM Thread Starter
greeninwyo
Jeepdaddy thanks for the help there both about the same price to do (gears/transfer) I checked it out and my current crawl is 285 and with the transfer kit would be 184, Im assuming that is pretty noticable? I think I might opt for the tera kit. Was wondering what you think of the Spartan locker by Yukon if you have heard good/bad. They seem like a pretty good locker for $250. Thanks for the help
Fjguercio- thanks for the gear calculator
80CJ- ya I still pull my hair out over my 75 from time to time but I got so much time/money in it now hahaa
i could use some input kw89425 Jeep CJ Forum 19 11-10-2009 07:28 PM
79 CJ7 - Need input TheLazyC Jeep CJ Forum 0 06-11-2009 07:37 PM
78' cj7 input?? bennyboyraptor Jeep CJ Forum 1 04-29-2009 08:54 AM
might be getting a CJ7 would like some input.. Magic2979 Jeep CJ Forum 14 07-27-2006 08:08 PM
maybe some input dukhntr4lfe Jeep CJ Forum 1 03-10-2006 08:33 AM
