Volts gauge burnt up, Lost the whole left side of fuse block - JeepForum.com
post #1 of 2 Old 10-23-2009, 10:09 PM Thread Starter
yojeep79
1979 CJ7
Today the volts gauge in my 1979 jeep cj7 burnt up. It grounded to the dash and started smoking. I cut the jeep off and unplugged it. now i have lost the wipers, the blinkers, pretty much the leftside of the fuse block..can anyone help me i need it.
yojeep79 is offline
post #2 of 2 Old 10-24-2009, 04:14 AM
John Strenk
John Strenk's Avatar
1976 CJ5
The fuse box is split into switched and non switched sections and it sounds as if you lost the whole switched section of the electrical system. Since the rest of the fuse box works, horn, brake lights, I don;t think you blew out the fuseable link.
You probably have a bad connection in the fuse box or in the ignition switch. It seems as if it could be in the Accessory side of the ignition switch. The rivets in the fuse box may have overheated and now making a poor connection. The plug on the ignition switch were the ACC feed comes may have overheated and now is making a poor connection.
John Strenk is offline
Aux. Fuse Block????? Stan99 Jeep CJ Forum 30 06-26-2009 04:50 PM
Fuel gauge windings burnt up rkbell Jeep CJ Forum 1 02-22-2009 01:03 PM
16-18 volts at the voltage gauge certifiablejeep Jeep CJ Forum 6 06-14-2004 04:53 AM
fuse block? cshutts Jeep CJ Forum 2 04-15-2004 09:28 AM
fuse block? onesojourner Jeep CJ Forum 4 01-24-2003 10:24 PM
