Voltage drop at coil? - JeepForum.com
post #1 of 3 Old 03-26-2004, 04:57 PM Thread Starter
motoxxxguy
1995 XJ Cherokee
Here's a strange problem I've never seen before, maybe someone can help me out here...
The 12+ wire going to the pos. terminal on the ignition coil is dropping from 12 volts to about 6.5 volts when connected. When not connected to the coil, there is a full 12 volts in the wire, but as soon as I connect the wire to the coil (which I just replaced as well), the voltage drops to 6.5V, not nearly enough to get any spark from.
Has anyone ever seen this before, and where should I start looking for the problem? i have never sen anything like this before!
-moto
1995 XJ
motoxxxguy is offline
post #2 of 3 Old 03-26-2004, 06:26 PM Thread Starter
motoxxxguy
1995 XJ Cherokee
Nevermind, I figured it out!
1995 XJ
post #3 of 3 Old 03-27-2004, 10:42 PM
Geer_hed
Geer_hed's Avatar
Were you checking voltage on the negative terminal after you hooked the POs wire up? for whatever reason you were doing this test, did you unhook the negative wire before testing voltage? I'm curious to know what you came up with....
85 CJ7 / 258 / T176 / Dana 30/ AMC 20
Geer_hed is offline
drop in voltage and loss of starting barlow Jeep CJ Forum 8 01-11-2010 08:53 AM
coil voltage/alternator question ctm Jeep CJ Forum 11 02-11-2008 04:18 PM
Too much voltage at coil? ecstrate Jeep CJ Forum 10 01-21-2005 10:45 AM
tfi coil voltage question lord_byron Jeep CJ Forum 22 07-29-2004 10:13 PM
78-86 CJ Voltage to Coil? rto Jeep CJ Forum 0 07-14-2003 03:19 PM
