voltage - JeepForum.com
post #1 of 31 Old 03-18-2004, 07:48 AM Thread Starter
MudMonster
MudMonster's Avatar
voltage
is it normal to have voltage drops when the engine comes down from high RPMs to idle (proably a little below from the sound of it).
"Don't be too proud of this technological terror you've constructed"
RED JEEP CLUB MEMBER #78
BIG GUNS AND JEEP OWNERS OF AMERICA CLUB MEMBER #3
Red Neck Jeep ClubMember#27Fire Engine Red '85 CJ-7, Howell FI-258, T-176, D300, 9", Warn Internal Hubs, Wagoneer front springs, RE Wrangler's in the rear, 33" TrXus', HEI conversion, Taurus fan, no emissions junk, and some 150w daylighters
MudMonster is offline
post #2 of 31 Old 03-18-2004, 08:55 AM
MudLover
MudLover's Avatar
yup. Happened in my Jeep and happens in the Cougar now (and it's got a brand new Alternator).
Marc
1979 CJ5 project
"Life is an issue of mind over matter. Ya see, I don't mind, and well...you don't matter."
Red Jeep Club Member #2
MudLover is offline
post #3 of 31 Old 03-18-2004, 09:26 AM
jeepsarecool
jeepsarecool's Avatar
1982 CJ7
Along the same lines, I've been wondering if there is an alternator with a little higher output that I could buy. Between my stereo system, H4 headlights, and blazer blower motor, my alternator is really struggling. With all of that going full blast, it dips down to about 10 volts.
jeepsarecool is offline
post #4 of 31 Old 03-18-2004, 11:08 AM Thread Starter
MudMonster
MudMonster's Avatar
i just put one in from alterstart, its nice.....
post #5 of 31 Old 03-18-2004, 12:54 PM
CJ-5
Delco
Delco makes a 130 amp. you may have to wire it in and fab a bracket, but this is the alt that was used in the late 70's cars that had all the bells and whistles. Air was the big power draw, cause the blower and clutch. Then they added automatic driving lights...... the list goes on, but that is the alternator that I would recomend. AND they are internally regulated too.
CJ-5 is offline
post #6 of 31 Old 03-19-2004, 07:38 AM
Geer_hed
Geer_hed's Avatar
Yes. If your regulator (onboard or not) is not operating within specs, you will see exaggerated fluctuations in voltage output as your gauge/multimeter realizes a more directly proportional relationship between RPM and the Alternator's cycle. Your regulator's job is to feed exactly (or as close to it as possible) the same amount of voltage no matter what the relationship to RPM and the alternator's output is, and then balance the charge against the relative charge on the battery so it doesn't overcharge and kill the battery over a long period of time.
85 CJ7 / 258 / T176 / Dana 30/ AMC 20
Geer_hed is offline
post #7 of 31 Old 03-19-2004, 11:04 AM Thread Starter
MudMonster
MudMonster's Avatar
well thats nice but the alternator is brand new from alterstart, which has a lifetime warrenty, its quality
post #8 of 31 Old 03-19-2004, 04:12 PM
CJ-5
regulator
have the regulator checked. Did you polarize the alt and reg when you hooked them togather ??
CJ-5 is offline
post #9 of 31 Old 03-19-2004, 06:06 PM Thread Starter
MudMonster
MudMonster's Avatar
the regulator is internal
post #10 of 31 Old 03-19-2004, 07:48 PM
CJ-5
oops
Okay, so stroke that one off the to do list.
have the alt tested, I know you said it's new and it's quality, but go the mile.
you could have a short or a ground somewhere, also load test the battery, just for kicks. I've had a batt with 2 dead cells, and I had some real wonky stuff goin on. Turned out to be the batt
CJ-5 is offline
post #11 of 31 Old 03-20-2004, 06:38 AM
HighCountry
I second CJ-5!
I agree with CJ-5... I would swap batteries and see if the situation changed. Testing a battery is NOT reliable unless you have access to a "Solid State" battery tester.
My recommedation is to go ahead and invest in one of the NICE new sealed batteries. A NAPA Orbital brand or an Optima brand is an excellent battery and you will never have to worry about corrosion again either!
Bruce from West LA (Lower Arkansas)
HighCountry is offline
post #12 of 31 Old 03-21-2004, 02:16 PM Thread Starter
MudMonster
MudMonster's Avatar
the battery thing occured to me, that some of the plates could be dead, so i went to Autozone and had em hook up their testing gear, they said everything checked out normal, the alt was fine, and the batt was fine. but the girl who did it was real condecending and in a voice that insinuated that i was an absolute moron she said "well does it start right up?" uhh yeah "well unless it doesnt start dont worry about it, then bring it back to us and we'll takke care of it for you" I was NOT HAPPY at that point as you can imagine.
post #13 of 31 Old 03-21-2004, 07:29 PM
HighCountry
Alto Zone?
Auto Zone? Do you know what sort of training those folks have? Go ahead, ASK them! I would not take that "test" for the last word.
Bruce from West LA
post #14 of 31 Old 03-21-2004, 08:55 PM Thread Starter
MudMonster
MudMonster's Avatar
Bruce from West LA
OOOOHHH believe me i know!!!!
So would the battery cause this stuff???
post #15 of 31 Old 03-22-2004, 05:39 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
Yes the battery can cause this stuff !
If your battery has a bad cell or two, it can't hold full voltage.
When decelerating and drawing a heavy current you will see the results in the meter.
Voltage Meters reflect the voltage in the battery not what is coming out of the alternator.
As suggested, a load test will reflect a bad call condition and have the alternator tested just to be sure.
This will give you a starting point.
Putting in a new battery before doing a test, is throwing money away and may result in damaging the new battery because the alternator may have a bad ground or shorted inside.
Luck,
Scrambler82
Do it right the first time !
Scrambler82 is offline
different voltage golferwt Jeep CJ Forum 6 06-14-2009 05:21 AM
Voltage Question fireslider Jeep CJ Forum 5 08-28-2008 10:00 PM
alternator voltage kappa505 Jeep CJ Forum 23 12-07-2006 09:02 PM
low voltage... jy4wvu Jeep CJ Forum 4 09-29-2006 03:54 AM
Voltage Reg?? cj5mudman4x4 Jeep CJ Forum 3 02-21-2003 04:10 PM
