voltage - JeepForum.com
post #1 of 4 Old 05-30-2011, 09:41 PM Thread Starter
albecker
1981 CJ7
voltage
I have been having problems with my voltage and cranking on my 1981 CJ7. I installed a new battery, solenoid, starter, and alternator, which fixed the cranking problem, but now whenever the engine bogs down the volt meter will go to zero the radio, dash lights and sometime even the headlights will go out. As soon as I race the engine the volts come back and everything else. Could I have gotten a bad alternator? Would welcome any suggestions. Thanks,
albecker is offline
post #2 of 4 Old 05-31-2011, 01:55 AM
raperfam
1977 CJ7
check all your grounds first!!!
raperfam is offline
post #3 of 4 Old 05-31-2011, 03:47 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Go to Zero? That's a big drop. You have a poor connection someplace. Maybe a bad cable or crimp.
I would pull apart all the terminal connections and inspect them for loose or corroded contacts. Check from the starter solenoid to the firewall from the firewall to the ignition switch from the ignition switch to the fuse box. Look for loose connections, corroded wires, Overheating.
Next time you have a failure, attach one lead of a DVM to the POS (+) on the battery. Run the other test lead down the wire. Any place you have any voltage showing is a bad connection and needs to be fixed. If it really goes to Zero, you could probably use a test light. A DVM wll give you a better look at poor connections.
Wires are made up of many strands of wire and you only need 1 strand for voltage but all of them to carry enough current.
And yes check your grounds, they are part of the circuit also.
John Strenk is offline
post #4 of 4 Old 05-31-2011, 04:02 AM
BagusJeep
1981 CJ7
Sounds like your major leads from the battery are knackered, either teh connectors themselves or the cables are corroded. cheap and eaily available generic cables will transform your electrics.
BagusJeep is online now
different voltage golferwt Jeep CJ Forum 6 06-14-2009 05:21 AM
alternator voltage kappa505 Jeep CJ Forum 23 12-07-2006 09:02 PM
low voltage... jy4wvu Jeep CJ Forum 4 09-29-2006 03:54 AM
voltage MudMonster Jeep CJ Forum 30 04-05-2004 01:27 PM
Voltage Reg?? cj5mudman4x4 Jeep CJ Forum 3 02-21-2003 04:10 PM
