Volt meter wiring - JeepForum.com
post #1 of 7 Old 07-02-2010, 10:26 AM Thread Starter
h2ojeep
1978 CJ7
Volt meter wiring
I am installing an after market voltmeter in my CJ. Using the great links that Mike Romian has on his posts, confirmed that the yellow positive wire and a black negative wire.
I note that the black wire is attached so that it is grounded to the dash via one of the studs through the mounting bracket holding the gauge in the dash and am sure that factory.
My question:
With my new install, I am grounding to a central point under the dash and was considering NOT using the OEM black wire for my new voltmeter. The current OEM gauge does not need that wire as noted above, the gauge is grounded to the dash. Was it installed from the factory to run as a ground from the dash to something else needing a ground? If I do not use that wire, will it eliminate a ground to something else that would not have one otherwise?
h2ojeep is offline
post #2 of 7 Old 07-02-2010, 03:32 PM
Mike Romain
The dash itself is a lousy ground. Running a ground wire to the bolt holding the meter in is a good idea. The wire is likely for that reason.
Mike
Mike Romain is offline
post #3 of 7 Old 07-02-2010, 04:35 PM Thread Starter
h2ojeep
1978 CJ7
Thanks Mike
I had already run a dedicated ground from the negative side of the battery to the dash and connecting those things needing one[a ground] to that central ground.
Sorry for misspelling your name, and sorry in advance as I will likely do it again, my curse.
I appreciate your contribution to this forum.
h2ojeep is offline
post #4 of 7 Old 07-02-2010, 08:49 PM
kakai81
Instead of running directly to the battery neg post. It might be better to run to your frame or fender well ground.
kakai81 is offline
post #5 of 7 Old 07-03-2010, 06:56 AM Thread Starter
h2ojeep
1978 CJ7
Thanks, good advise.
As a matter of convince, my GPS and CB are powered off a cigarette lighter. Yea, I know that is not the best, but redoing the GPS would be a major pain. My problem then was that I had a background buzz in my CB and every time I started the engine, my GPS would have to reset taking time to find satellites, and breaking the "tracking record".
I ran no. 10 wire direct from my battery (both +&-) to my lighter power, so I already have that no 10 ground wire under the dash. No buzz, no re-starts on the GPS. I already have a central fire wall ground.
h2ojeep is offline
post #6 of 7 Old 07-04-2010, 04:51 PM
Mike Romain
I am up in the rust belt and fenders for sure are flaky grounds with the frames not fairing much better with all the rust flakes and scale. We usually use a dedicated buss for grounds right off the battery. Less pain in the butt in the long run up here. Makes for better/cleaner CB too as mentioned.
Mike
post #7 of 7 Old 07-04-2010, 06:00 PM
kakai81
Cool, good idea Mike. Any method that keeps noise out of the CB will definatly be looked into by me.
kakai81 is offline
Why Would Volt Meter Flicker??? qwert98 Jeep CJ Forum 8 11-29-2013 10:23 AM
Volt Meter Jumping hieber22 Jeep CJ Forum 8 10-08-2009 08:00 AM
Aftermarket Volt Meter Wiring Muttmutt Jeep CJ Forum 1 04-07-2009 03:16 AM
Volt Meter issues? mmillen Jeep CJ Forum 31 12-13-2008 01:14 PM
74 oil and volt meter guage? my old cj Jeep CJ Forum 1 11-14-2008 09:06 PM
