Volt Meter Issue - JeepForum.com
post #1 of 5 Old 10-12-2013, 04:54 PM Thread Starter
Kirks
1977 CJ5
Volt Meter Issue
Just installed a new Auto Meter volt meter. When I turn the blower motor or the head lights on with the jeep running the volt meter drops clear to the left. Could I have a bad ground. Jeep had a volt meter in it I used the same wires. The only reason I replaced it the needle was off.
Kirks is offline
post #2 of 5 Old 10-12-2013, 05:04 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Take a DVM and check the voltage at the voltmeter.
It could be a case of a really bad wiring harness.
It could be a bad ground also. If the ground was bad there could be a voltage drop across the ground messing with the volt meter.
John Strenk is online now
post #3 of 5 Old 10-12-2013, 05:53 PM Thread Starter
Kirks
1977 CJ5
I should have mentioned that it reads 13.8vkey on not running and 15v running.
Kirks is offline
post #4 of 5 Old 10-12-2013, 06:14 PM
dg6772
Just fixed the same problem with mine, it turned out to be a bad ground to the meter. New ground, and all was better.
Good luck!
Dave in Muskegon
dg6772 is offline
post #5 of 5 Old 11-03-2013, 05:10 PM Thread Starter
Kirks
1977 CJ5
[QUOTE="dg6772"]Just fixed the same problem with mine, it turned out to be a bad ground to the meter. New ground, and all was better. Good luck! Dave in Muskegon[/QUOTE
Took me several weeks to get it checked out. It indeed was a poor ground. When I replaced the gage I used the same ground but further checking revealed the fact that the other end was not properly grounded.
Kirks is offline
