Vinyl floor cover - JeepForum.com
post #1 of 6 Old 07-20-2007, 08:07 PM Thread Starter
jnldr
Vinyl floor cover
So I think I got a nice pretty original rust free CJ7 but the carpet is well worn(and Garnet).I am sure I can find original carpet kit to go back in it but I would like to not have to worry with keeping it clean.Since the Jeep seems to be good example I hate to put bedliner on the floor.
? is: HAS ANYONE USED THE VINYL FLOOR KITS FROM QUADRATEC OR JC WHITNEY?
If so,how are they and do they glue down or will they just fit in. I was thinking this would be a good solution for now that I could easily remove or just place carpet over in the future.
Thanks,
JNLDR
jnldr is offline
post #2 of 6 Old 07-21-2007, 07:12 AM Thread Starter
jnldr
Anyone Use This Product?
jnldr is offline
post #3 of 6 Old 07-21-2007, 07:44 AM
gojeepin
1983 CJ7
I think it'll trap dirt and water beneath itself and lead to rust.
Have you thought about Herculiner (DIY) or Linex? My Jeep is "wash and wear" with the vinyl seats and Linex inside the tub.
Just a thought.
gojeepin is offline
post #4 of 6 Old 07-21-2007, 07:49 AM
cavedweller
1979 CJ7
What are you going to be doing with your Jeep? Is it going to be getting wet inside quite a bit? I would tend to worry about the drop in liner trapping moisture and causing rust...especially if the liner moves around a bit and causes scratching of the paint. I have never had one so I don't know for sure, but I do know that this is one of the complaints of the drop in bed liners in pick-ups. If they don't fit well they can cause vibration noises that are irritating too.
I know you have a pretty pristine CJ from what you've described and I can understand not wanting to modify it too much (I am into restoration way more than modification myself) However, if you plan on doing stuff that will be getting the inside wet and/or muddy frequently I think you should re-think getting a spray in liner like Rhino. That is what I am doing after much consideration and research on the subject. I want to preserve my CJ best I can and I am going to so much effort to restore it. I think that that the Rhino is one mod I'm willing to make for the greater good.
Don't know if this helps at all but at least you have a post on here--right?
cavedweller is offline
post #5 of 6 Old 07-21-2007, 07:55 AM Thread Starter
jnldr
Rust issue
That is the particular issue I was concerned about - trapping moisture and water and doing more harm than good. I will use my jeep a liitle afield but VERY lightly. Mostly will be a cruiser. I may go with bedliner but probably go with an original carpet and put some type of heavy vinyl floor mats over when and if needed. Thanks for the replies.
JNLDR
jnldr is offline
post #6 of 6 Old 07-21-2007, 10:06 AM
jeepwhore
Why not spray liner on the inside and put replacement carpets over top? You can retain the original look with no worry of rust occuring beneath it (provided you remove the rollbar during the liner installation) and remove the carpet when you feel like doing a little exploring ion the backroads. Best of both worlds IMO.
jeepwhore is offline
Floor cover for shifters timmick Jeep CJ Forum 6 04-19-2009 07:17 AM
vinyl seat cover (factory replacement) where to buy? COBRA5LADDICT Jeep CJ Forum 2 04-28-2008 04:21 PM
Roll Bar Cover - Vinyl or Denim? CJ83 Jeep CJ Forum 8 04-20-2008 04:15 PM
floor cover cwbrg Jeep CJ Forum 5 01-19-2006 06:17 PM
Vinyl Floor AUTO-5 Jeep CJ Forum 4 10-22-2005 03:53 PM
