VIN location on engine - JeepForum.com
post #1 of 15 Old 09-10-2011, 12:17 PM Thread Starter
Ollie09
1983 CJ7
Where would I find the VIN number stamp on a 80's CJ7 with the inline 6?
Thanks,
Gary
Ollie09 is offline
post #2 of 15 Old 09-10-2011, 12:51 PM
agear
There is an engine build date code on the passenger side of the engine on a raised flat surface on the block between the 2nd and 3rd cylinders. There is also an engine block casting number on the drivers side of the block
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #3 of 15 Old 09-10-2011, 06:08 PM
Pathkiller
1974 CJ5
The VIN is not on the engine.
Pathkiller is offline
post #4 of 15 Old 09-10-2011, 06:24 PM
agear
That ofcourse is on the narrow plate above your windshield wiper motor on the inside of the jeep.
agear is offline
post #5 of 15 Old 09-10-2011, 07:00 PM
mopar346
Although I don't know Jeeps or even AMCs for that matter I do know cars and starting in late 68 VINs are on all engine installed at the factory, not on warranty or over the counter replacements. I believe it was a federal mandate so if I were ask to bet on it, I'd bet the farm, but again I don't know Jeeps so I could be wrong.
Careful your character's showing
mopar346 is offline
post #6 of 15 Old 09-10-2011, 07:45 PM
brownbagg
1930 MK Compass
you are wrong, vin never been on any engine, there is a engine number but its not a vin number. there is also a tag on the firewall with the vin number on it
brownbagg is offline
post #7 of 15 Old 09-10-2011, 08:02 PM
mopar346
Well, I know for fact it is on all or most engines or maybe to clarify the build plant, year and sequential number (serial number part of the VIN). Where do you think the term matching numbers comes from. It is also on transmissions. Look on e-bay and you will probably find a number of engines for sale with the VIN number posted. It is not even a question, the only question I cannot definitively answer is if they were on Jeep/AMC engines but again I believe it was a federal mandate. I will look for one on my 360 tomorrow and then I will be able to answer to that.
http://www.ehow.com/how_4814893_read-engine-vin.html
mopar346 is offline
post #8 of 15 Old 09-10-2011, 08:22 PM
mopar346
This is off a Mopar site, you will notice many lost and founds for engine block #XXXX:
http://www.transamcuda.com/lostandfound.htm
This is from a Camaro site:
http://www.camaros.org/drivetrain.shtml#PadStamps
mopar346 is offline
post #9 of 15 Old 09-10-2011, 08:25 PM
keith460
Jeep. There's Only One
keith460's Avatar
Not a VIN as mentioned but just a build code when the engine was built. I'll give my CJ-7 as an example.
The stamping on the engine as shown in the picture below shows: 403C15 which means it's a 258CID engine built on March 15, 1984.
1st Character (Year)=4 or 1984
2nd & 3rd Characters (Month)=03 or March
4th Character (Engine Type)=C or 258
5th & 6th Characters (Day)=15 or 15th day
I'm an original owner of my Jeep and I ordered it during the first week in March of 1984 and received it at the dealership somewhere around March 27th or 28th. Took a little over three weeks to get from the time the order was placed.
1984 CJ-7 Renegade
keith460 is online now
post #10 of 15 Old 09-10-2011, 08:29 PM
mopar346
I maybe confused are ya'll saying Jeeps didn't or no vehicle did? What about other AMCs?
mopar346 is offline
post #11 of 15 Old 09-11-2011, 06:00 AM
keith460
keith460's Avatar
I know Jeep did not put VIN numbers on engines just date codes when built. If your Jeep was built on a Wednesday, you could have received an engine that was built the week before.
1984 CJ-7 Renegade
post #12 of 15 Old 09-11-2011, 06:14 AM
papa355
1977 CJ7
OP asked for VIN "on engine", however as stated the "vin" is not on the engine, only a build code. maybe OP needs to clarify which # they actually need........... . then maybe you won't be confooooosed....(J/K) ;p
papa355 is offline
post #13 of 15 Old 09-11-2011, 06:39 AM Thread Starter
Ollie09
1983 CJ7
I came from the 70's Corvette world and all the engines, trannies and rear axles had the last 6 digits of the VIN number stamped on them. That's how you could tell if it was a "numbers matching" car (original driveline to the car). I thought it was a goverment requirement for all cars but maybe Jeep was considered a truck which may have different rules. On Chevy V8's, the stamp is on a boss located on the right front of the block.
Gary
Ollie09 is offline
post #14 of 15 Old 09-11-2011, 07:39 AM
mopar346
My confusion is about the disagreement, I understand the OP was asking about a VIN for a Jeep engine. I have found info that supports Jeeps didn't put VINs on engines this morning, but I thought some of you were implying no engine had a VIN which as Ollie points out is wrong. I too thought it was a law but somehow Jeep got around it , what I cant find is for how long, as in starting in 19XX they started, I know it is a Chrysler practice so I assume they started when they became part of Chrysler.
mopar346 is offline
post #15 of 15 Old 09-11-2011, 04:07 PM
papa355
1977 CJ7
Gary
I knew what you were asking.
Text can be interrupted many ways.
papa355 is offline
Location of engine number? kmewing Jeep CJ Forum 0 05-30-2009 08:58 AM
Fuel Filter Location 4 cyl 151 gm engine kuhndogs Jeep CJ Forum 2 02-06-2009 08:56 PM
86 cj7 ECU location and what it looks like takisanjeep Jeep CJ Forum 1 04-15-2007 08:43 PM
CJ5 VIN location plogue Jeep CJ Forum 2 09-15-2006 12:28 PM
location gumby Jeep CJ Forum 3 09-13-2003 05:06 AM
