vin location - JeepForum.com
post #1 of 7 Old 07-28-2001, 07:08 PM Thread Starter
dusty
Post vin location
on the cj7 frame where exactly are the vin numbers located.
dusty is offline
post #2 of 7 Old 07-28-2001, 07:54 PM
only in a jeep cj
Post
I have seen date codes stamped into the frames on the rear cross member (in front of gas tank), but not the VIN. That would be on the top of the wiper motor plate and on the tag just under the steering staft on the firewall.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 7 Old 07-31-2001, 10:40 AM
GroundUpCJ7
Post
There is normally a plate or sticker in one of three locations (that I have seen). A sticker on the driver's side of the dash, a sticker on the inside of the rocker panel on the driver's side near the floor, and a plate on the driver's side of the firewall near the top. Most likely, if the Jeep has undergone any major body repairs, the VIN is gone. In my case, the letters have faded or worn off, and I can't read them anymore, but that's ok...I'm replacing the frame and tub anyway.
It's not so much a labor of love as it is shear determination.
GroundUpCJ7 is offline
post #4 of 7 Old 08-03-2001, 12:23 AM
abc
Post
Hey,
Frame, passenger side, rear wheel "hump", on top. 81 CJ7 I took down to the frame had it there, I didn't see it until I had ground off the whole frame.
Later
abc
'85 CJ7
abc is offline
post #5 of 7 Old 08-14-2001, 12:27 AM
JeepTrickz
Post
Mine is a 85 cj7 and it is just like groundupcj7 says....driver side dash and driver side firewall.
JeepTrickz is offline
post #6 of 7 Old 11-19-2007, 08:40 AM
SkyHarborCowboy
1983 CJ7
Where is the sticker on the drivers dash? I need an exact location.
Thanks,
Joe
Thanks,
Joe
1983 Jeep CJ7 258 6 Cylinder with Weber Offroad Carb, HEI Ignition, Front and Rear Lock Right Lockers, Slick Rock Spring Hangers, 4" Suspension, Stainless Brake Lines and Quick Disconnects, TJ Flares, 33" BFG MT's, T5 speed (Soon To Be SM465 with Novak Adapter), Roll Cage, Smittybilt Double Tube Bumpers Front and Rear (They will be narrowed soon)
SkyHarborCowboy is offline
post #7 of 7 Old 11-19-2007, 11:11 AM
OkieKid
Thanks,
Joe
Your '83 did not have one on the dash. That was prior to '81 IIRC. You should be able to find it in three locations on your '83. There should be a plate on the firewall below the wiring harness connection. There should be another plate riveted to the windshield frame with the wiper motor. The VIN tag/strip will be riveted on the top of this plate. If you have a dash pad, there is a "notch" in the pad for it to be seen from the outside. The VIN should be "stamped" on the passenger's side frame as described above.
OkieKid is offline
VIN # location HELP??? specops72 Jeep CJ Forum 7 09-21-2017 11:17 AM
CTO location adman02 Jeep CJ Forum 1 04-19-2009 09:28 PM
'74 CJ5 vIN LOCATION?? foxracer677 Jeep CJ Forum 6 03-13-2009 06:12 AM
CJ5 VIN location plogue Jeep CJ Forum 2 09-15-2006 12:28 PM
VIN Location Help Jordy Jeep CJ Forum 7 07-15-2006 10:56 PM
