Viewers Choice "you" recommend changes CJ7 with 304 - JeepForum.com
post #1 of 19 Old 03-03-2012, 02:30 PM Thread Starter
Tigerpaw
1983 CJ8
This one's for anyone with time to give recommedations on organizing and upgrading with in limits under the hood. Budget is $500 bucks. What I already have--new carb, new dizzy, newer timing cover doing oiler upgrade, new water pump, new dizzy drive gear and dizzy gear, new timing chain, new fuel pump have upgraded headlights to run from a switch and relays. What I do is hunt with this Jeep no high water, little mudding, has a winch, need more lights, I'm no master mechanic just a country boy with his 12th jeep in 45 years. I have 2 weeks until turkey season this thing must roll.
Tigerpaw is offline
post #2 of 19 Old 03-03-2012, 03:58 PM
bigredisb
1979 CJ7
I would say a mild RV cam, performer intake (you can still run your 2 barrel carb with it and notice a difference, plus it shaves a ton of weight). You could find a used MSD 6AL on craigs list cheap as well. Headers wont hurt either.
1979 CJ7 aka "Christine" Build Thread:
2013 Rubicon Unlimited build thread:
bigredisb is offline
post #3 of 19 Old 03-03-2012, 04:36 PM
Shiftace
1977 CJ5
Personally I'd start getting the parts back on it!
Originally Posted by gpets View Post
...it is perfectly acceptable to take a sawzall to anything you can't figure out, that is how we all learn.
Shiftace is offline
post #4 of 19 Old 03-03-2012, 05:37 PM Thread Starter
Tigerpaw
1983 CJ8
Waiting on the timing chain set from bulltear be here Monday. flhbagger is sending me an orfice for the oil mod on the timing cover be here monday then i'm going back together. Cam does sound good but motor is very strong. How much work is replacing the cam?
Tigerpaw is offline
post #5 of 19 Old 03-03-2012, 05:40 PM
sandandson
I'm with this dude. Don't even know where to start if the basic stuff isn't in place.
Will be an awesome project though!
'98 TJ: 4.0L, Banks header and catback exhaust.
2.5" SL +.75in spring spacer, 33" XTerrains.
4.10's, Aussie Locker up front, 8.8w/LSD.
GR8Tops Exogate, XRC-8, Monstalined tub.
sandandson is offline
post #6 of 19 Old 03-03-2012, 06:25 PM
chopki1
1981 CJ7
4 cans of black spray paint,1 can of black engine paint,1 can of aluminum engine paint. 1 roll of black wire loom and a roll of black electrical tape. Total cost probably 20-25 bucks and it will give you something to do once you order whatever other parts you decide on and will help make the delivery time go by quicker.
chopki1 is offline
post #7 of 19 Old 03-03-2012, 06:41 PM
mvbrady
I'd spend it on 50 gallon barrels , gas, and fuel stabilizer...i keep hearing gas prices are gonna blow this summer.
mvbrady is offline
post #8 of 19 Old 03-03-2012, 07:03 PM
arkiemurph
Get u one of those work lights out of a Chevy truck (90s) and mount it under your hood. It reels out and in, has about a 15 ft cord on it. Handy as a pocket on a shirt! I mounted mine close to the radiator kind of towards the solenoid.
Murph
Love thy neighbor, but don't mow down the hedge.
arkiemurph is offline
post #9 of 19 Old 03-03-2012, 08:25 PM
Shiftace
1977 CJ5
They're not too bad but you do need to dig down to the lifters and pull them up.
Then if your cam bearings are worn...
I think working your way towards an EFI is a better option
Shiftace is offline
post #10 of 19 Old 03-03-2012, 08:40 PM Thread Starter
Tigerpaw
1983 CJ8
What about electric radiator fans? Dual batteries? Upgrade alternator? Have ya'll added any of these in the past?
Tigerpaw is offline
post #11 of 19 Old 03-03-2012, 08:43 PM
mopar346
I agree, I'd have to clean up the engine bay. Performance wise cam and intake as mentioned. Would have been nice to now vitals before it was pulled down, I would have been temped to do the shortblock with a cam and them change heads and intake later.
THe items you just mentioned would only be done out of necessity, are you having any concerns with any of those items?
Careful your character's showing
mopar346 is offline
post #12 of 19 Old 03-03-2012, 08:55 PM Thread Starter
Tigerpaw
1983 CJ8
Wasn't sure it the electric fans would be better than the stock, the others battery and alternator would be to back up extra lights and winch. Not having any real issues other than the carb, put on a holley 600 cfm that just could not tune and most folks said it was to big for the 304 as is. So I put 2 barrel back on today so when I fire it back up we'll see. This all started from a water pump replacement only.
What type of spark plug wire looms will work best with the 304.
Tigerpaw is offline
post #13 of 19 Old 03-03-2012, 09:26 PM
mopar346
600 CFM shouldn't be too much for a 304, maybe your jets, accel pump, power valve, was but 600 simply means it really wont flow over that, when the blades are closed it's a 0 CFM (basically) and when they are crack open it pulls what it wants.
mopar346 is offline
post #14 of 19 Old 03-03-2012, 10:28 PM Thread Starter
Tigerpaw
1983 CJ8
I'm going to move it to a cj5 with a 304 that is more of a mud racing unit I found at an auction. maybe I can tinker with it more on a unit i don't need to run as often. well thats another project. put the two-barrel on the camo jeep.
Tigerpaw is offline
post #15 of 19 Old 03-03-2012, 10:35 PM Thread Starter
Tigerpaw
1983 CJ8
Okay paint what black and what silver on the engine? I'm all for cleaning the inside up- What degreaser do you recommend i've tried Gunk and it doesn't work like it did 20 years ago, i have a pressure washer to blast it off with. but need a degreaser..
Tigerpaw is offline
builds , engine , fuel assembly , lights , wiring harness
JeepHammer...Your Carb Choice for a "Built" 258? cfljeep Jeep CJ Forum 9 10-19-2012 07:22 PM
"Convertible" Lift Shackles 1 1/2" to 2"? FamillyCJ7 Jeep CJ Forum 21 10-09-2010 10:03 AM
no power coming out of the solenoid with the switch in the "start" or "on" positions SPless Jeep CJ Forum 5 07-13-2010 05:41 PM
JKS "Quick" or "Quicker" disconnects? cincyjeeprs Jeep CJ Forum 0 05-15-2009 10:33 AM
"Green Grease" or Lucas "Red N Tacky #2" Curt Reinhardt Jeep CJ Forum 3 07-16-2008 08:09 AM
