-   -   VIDEO: Is this a normal amount of play in the lower steering column bearing? (http://www.jeepforum.com/forum/f8/video-normal-amount-play-lower-steering-column-bearing-1660705/)
Grims 10-07-2013 04:22 PM
I can't find this part locally so I am trying to figure out if I should wait for a replacement to be shipped to me before putting the steering shaft back on or not. Also, not shown in the video, but the column shaft pushes back up into the firewall. I am not sure if that's normal or not, but it makes re installing the steering shaft very hard.
chromegrille 10-07-2013 09:32 PM
The lower column bushing/bearing could be bad.
In a perfect world, I suppose no play would be ideal.
As for re-installation, you're fighting the upper shaft preload spring, normal.
Another set of hands pushing down gently on the steering wheel would solve that.
Grims 10-08-2013 11:11 AM
Hmm, the steering wheel doesn't seem to have any pull/push correlation the shaft. I had to pull it back out with needle nose pliers when I pushed it up too far. I'm sure I can get it on there if I hold it down with a pair of vice grips or something. Just wanted to make sure that was normal.
Bmacbride 04-23-2014 01:56 PM
Mine has the same amount of play. Does not seem right. I can feel it while driving when I hit a bump
Not sure if replacing the bearing would solve the problem
Grims 04-23-2014 02:00 PM
I ended up replacing the bearing and it resolvd most the play. Didn't really fix the issue I was looking to resolve though.
The time now is 12:31 PM.
