Quantcast VIDEO: Knocking sound, need help. CJ5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > VIDEO: Knocking sound, need help. CJ5
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSpartan Lockers FREE SHIPPING Excellent PricesGR8TOPS Introduces the Exogate HD Tire Carrier
Old 09-22-2008, 02:08 PM   #1
3S00W
Video of my CJ5 first run... Listen to the knocking sound. It goes away when I press the clutch in completely. And comes back when releasing the clutch. Anyone gimme some ideas to what may be causing this.
http://tinypic.com/player.php?v=2e3wmqa&s=4
M O O S E
J E E P : the dirtiest four letter word
1980 CJ5 5.7L 2006 TJ 4.0L 1990 XJ 4.0L(RIP)
3S00W is offline   Reply With Quote
Old 09-22-2008, 02:09 PM   #2
3S00W
couldn't figure out how to embed it on here.
M O O S E
Old 09-22-2008, 07:54 PM   #3
jjlove
1978 CJ5
Did you just do some work to it? While I was doing a T18 swap, the flywheel bolts were just a little bit longer and they hit the inspection cover. It sounded just like yours.
jjlove is offline   Reply With Quote
Old 09-22-2008, 08:25 PM   #4
3S00W
I've just changed the fluid in t-case n rear so far, doing the front n tranny soon... I've only had it for two months and it's only been running for a month of that...
M O O S E
Old 09-22-2008, 08:31 PM   #5
keysdezees
At first I thought throwout bearing... but sounds too loud and consistent when moving in gear. More to follow...
keysdezees is offline   Reply With Quote
Old 09-23-2008, 06:39 PM   #6
3S00W
bump......
M O O S E
Old 09-23-2008, 09:39 PM   #7
Lifesgoodhere
1989 XJ Cherokee
nice tummy...lol
No, I don't think the the throw out bearing ether. Have you looked underneath to make sure the exhaust isn't shaking against anything? it sounds like when you take a poker card and get it too near a fan that's spinning
just my 2 cents
1949 Jeep Truck; just needs paint
*My YouTube videos Subscribe!
*My Jeep Build Thread >>Epic project
Certified Jeep Expert, and Volvo Mechanic
Lifesgoodhere is offline   Reply With Quote
Old 09-23-2008, 10:22 PM   #8
RoscoeJ
KnOCK
I would say flex plate bolts hitting cover. When there is torque ,between the motor and trans . Could be wrong plate or the starter took a shot and bent the plate in to hit the bolts,or a bolt just worked loose.imo. I had a car with same problem ,my problem was wrong plate.
RoscoeJ is offline   Reply With Quote
Old 09-23-2008, 10:53 PM   #9
Skerr
Jeep Vacuum
Skerr's Avatar
At least yours moves under its own power!
Kerrdog
Go Fish! <*////><
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM!
Skerr is offline   Reply With Quote
Old 09-23-2008, 11:25 PM   #10
Bear-Olemiss
1981 CJ5
Yea, nice belly... all glistening with sweet. hahah in a non-homophobic way.
BAIL! "Welder's have hotter rods"
Arc-Up Welding Inc.
Vicksburg, Ms
Bear-Olemiss is offline   Reply With Quote
Old 09-24-2008, 05:40 AM   #11
jgladf
Since you still have the noise in neutral, it would have to be caused by something on the input shaft or the counter shaft in the transmission. Those are the only parts that are still moving in neutral. Either you have a really bad bearing or a broken tooth on one of the gears. The fact that the noise stops when you press the clutch isolates your problem to the transmission.
jgladf is offline   Reply With Quote
Old 09-24-2008, 06:56 PM   #12
3S00W
bump......
M O O S E
Old 09-24-2008, 08:29 PM   #13
ecvMatt
1966 CJ5
I had a similar problem a few years ago when I was swapping a muncie into a toyota. IIRC the clutch fork was in backwards and was hitting the fingers on the clutch. Once the pedal was pushed in, it allowed for clearance.
[URL="http://www.pancan.org/"]HELP SOMEBODY![/URL]
ecvMatt is offline   Reply With Quote
Old 09-26-2008, 07:36 AM   #14
3S00W
bumpy bump
M O O S E
Old 11-14-2008, 01:31 PM   #15
CJ_JEEPER
I’ll take a stab at it.
I have 75’ CJ5 and I had a similar nock with similar reactions when engaged and disengaged. During my rebuild I did not realize that there is a pilot bushing in the flywheel that should have been replaced while I had it torn apart. It looks like a little brass ring that is press fit in there. Was a pain in the arse to get out, but when I did there was hardly anything left to it when compared to the new one I put back in. My problem was solved.
Good luck
CJ_JEEPER is offline   Reply With Quote
Glock Forum
