I put in a new transmission, clutch & flywheel about two thousand miles ago, and starting today I am getting this grinding noise when trying to shift into any gear. The noise will continue until I let the clutch out. So, after it gets going just having the clutch in with the tranny out of gear can cause it.
Seems to do it most often when going into a gear, but it has done it once or twice while in neutral with the clutch in. It goes into gear fine, it just makes that noise more and more often.
Running out of gear oil or the wrong gear oil are my first guesses then. You need to be running synchromesh gear oil, a modern plain GL5 gear oil will seize up the synchros.
Or the clutch getting out of adjustment. The pedal should have an inch or so of free play at the top.
Get that motor oil out of there and refill with 75W-90 syn tranny oil.
How much pedal freeplay do you have on the clutch? You only want 1-1 1/4" at most.
LG
Don't bet on it :thumbsup:
And won't know till it's done.
Show me where Borg-Warner ever said to use engine oil in their Jeep T-5.
BW said to use ATF at one time, and paid dearly for that screw-up.:thumbsup:
AMC/Jeep even had a special 'stink' oil made up and sold at the stealerships.
LG
Talked to the guy who built the transmission, and he had a pretty good argument for it being a clutch issue, and said it wouldnt matter if I had used water for tranny fluid...if the clutch is working right nothing in the transmission should be turning with the clutch pressed in. So, I'm going to adjust it in some to see if maybe it just isn't fully engaging. It is odd that would suddenly become an issue though.
I adjusted the clutch out 4 turns and gave it a drive. Around a mile in I get the howling noise while in first gear but the clutch pressed in. It got progressively worse from there on but only did it with the clutch pressed in. I don't feel any vibration that sound like the transmission is grinding.
Could that be the throwout bearing then? Only seems to do it while the clutch is in, regardless of if the transmission is in or out of gear.
Being the clutch is pressed that should rule out the transmission as the culprit.
Meh, as I was putting the clutch rod back together the darn thing fell off the front ball joint and whacked me in the head. How is this thing supposed to go back on? Does it snap on with a pair of plyers?
Are you sure the tub hasn't shifted on its mounts? Or maybe you have a broken tyranny or engine mount?
There is a C clip used to hold that in. They can be had online as part of the bell crank bushing set. If the clip is gone, the nylon bushing might be dead also which sure throws the adjustment out.
You don't adjust a clutch by feel, you adjust it until you have a little more than 1" of flop at the top of the pedal. If it doesn't work there, something else is wrong.
No, that is the proper place, just there are other clips that can pop off so the whole thing falls on your head.
Still worth checking the mounts for the reason it went out of adjustment so fast. Just that part didn't break because of the mounts.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
