vibration while driving - JeepForum.com
post #1 of 6 Old 11-17-2002, 09:17 AM Thread Starter
75jeepcj
Question vibration while driving
There has been a vibration in my jeep that has been coming and going. Sometimes its there while I drive slow but more often when im in 3rd gear(3speed trans) going over about 35mph. Dont know if it is the transmission, the rear end, or maybe just an unbalanced wheel. Any suggestions on where the problem may be are appreciated.
75jeepcj is offline
post #2 of 6 Old 11-17-2002, 12:12 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Could be any number of things. Do you have a lift? Has it (the bad vibe) been there for a long time? Did it start after a recent modification (lift? new tires?). Does it seem like it's coming from the front or rear? If it starts and you shift into neutral is it still there? I would check the driveshaft universal joints first. Also check to see if all the wheels have their balance weights. Check for general sloppiness in things like tie rods, ball joints, wheel bearings. Hopefully you'll home in on it.
BESRK is offline
post #3 of 6 Old 11-18-2002, 04:42 PM Thread Starter
75jeepcj
just put a 1 1/2 inch lift and i'm pretty sure its coming from the back wheel(s)
75jeepcj is offline
post #4 of 6 Old 11-18-2002, 05:53 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I wouldn't think that a 1.5" lift would affect driveshaft angles enough to cause vibration but who knows? I would make sure that the transfer case output yoke and rear axle pinion yoke are on the same plane or with the pinion pointed about 1-2 degrees lower. If the lift caused your rearend's pinion to point up a little it may have induced a driveshaft vibration.
BESRK is offline
post #5 of 6 Old 11-18-2002, 09:27 PM
SamFromCO
SamFromCO's Avatar
What type of lift did you put on (spring, shackle, or body)? Have you checked your u-joints?
SamFromCO is offline
post #6 of 6 Old 11-19-2002, 08:07 AM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Cool
I would make sure that the u-bolts and springs are all seated correctly, and not loose. If something is able to move around back there, it will vibraite a lot.
A quick and cheap way to tell (assuming everything is bolted correctly) if the mild lift its self is the cause (could be on such a short CJ-5), is to throw a couple of hundred pounds in the back, effectively compressing the springs, lets say 2". If there is then no vibraition, the angle is too great, at least for the u-joints you have in.
Good luck
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
Vibration SavSilvrCJ Jeep CJ Forum 3 11-06-2007 06:01 AM
vibration CJ5911 Jeep CJ Forum 7 11-26-2005 01:43 PM
vibration rifed1 Jeep CJ Forum 1 07-23-2005 12:09 PM
Bad Vibration 350JeepCj5 Jeep CJ Forum 4 04-28-2004 04:58 AM
Vibration at 35 MPH and up - HELP !!! sbestmann Jeep CJ Forum 6 08-22-2003 05:33 AM
