vibration at speed: u-joints? - JeepForum.com
post #1 of 4 Old 02-24-2004, 08:03 AM Thread Starter
NJCJ7
NJCJ7's Avatar
the cj's been having some pretty bad vibrations at hiway speeds. Engine's smooth as silk, so i am thinking drivetrain somewhere. Would new u-joints fix this? there is also a kind of ringing sound sometimes when i let off the gas... seems i read somewhere that that was a sign of u-joints being bad too... any input appreciated...
1985 CJ7 MC2100,TFI, 2.5" BDS suspension, Full Cage, 31" Mud Tires, 1/2" MORE shackles, Aussie Locked AMC 20
NJCJ7 is offline
post #2 of 4 Old 02-24-2004, 11:09 AM
jeepmor
jeepmor's Avatar
good call
Sounds right, that ringing sound is a clunk from the u-joint due to wear, letting off the gas makes it go from driving to driven, and the slop is the clunk, the resulting noies is travelling into the driveline, making it a bell of sort. Climb under the rig and try to move the joint, it should be obvious which it is once your under the rig. There should be no slop in the u-joint, if there is, replace it. And since you'll have the driveshaft out, replace both the tranny and diff end.
jeepmor
jeepmor is offline
post #3 of 4 Old 02-25-2004, 06:43 PM
SNiPeRX
I agree 100% I have a 84 cj7, and sunday i replaced my U Joint, and its running great now. I heard a rattling sound when i would let off the gas. The sure way to figure out if thats your problem is to put it in reverse, it will make a clank sound when you begin to move, or just climb under your car and shake the drive shaft. But im almost 100% sure that your problem is your U joint.
SNiPeRX is offline
post #4 of 4 Old 02-26-2004, 07:29 PM
Lightningdon
Lightningdon's Avatar
One other thing to think about......I had noise and vibration in my CJ. I finally tracked it to the input shaft bearing in my tranny. Just don't overlook that possibility.
'97 TJ
'75 CJ5 304cid, t18 tranny w/granny low, model 20 T Case, DANA 44 rear, 30 front, 4" suspension lift, 33" tires, in need of more work!
"The only thing necessary for the triumph of evil, is for good men to do nothing." (Edmund Burke)
Lightningdon is offline
Can a 63' 3 speed be converted to a 4 speed jgrassw Jeep CJ Forum 5 08-17-2009 07:54 PM
Clutch Pedal Vibration 4.2L 5-Speed Borg-Warner T-5 ddumbauld Jeep CJ Forum 9 08-14-2009 02:03 PM
D30 Ball Joints & U-Joints. Any Write-ups? DT5150 Jeep CJ Forum 7 07-02-2008 07:44 AM
Dust Covers Ball Joints U-Joints 6 bolt Hubs anwallac Jeep CJ Forum 5 05-16-2007 12:08 PM
Low Speed Vibration dporta Jeep CJ Forum 14 01-02-2006 08:37 AM
