Vibration Issues near Model 20 Transfer Case - JeepForum.com
post #1 of 5 Old 01-09-2010, 11:26 PM Thread Starter
Death_Eagle_571
1976 CJ5
Hey guys, I got an Issue around my transfer case, it feels like the rear driveshaft u-joints are shot, but I checked them, and they seem fine, the yoke seal on the rear driveshaft yoke on the t-case is busted, and has been slowly leaking, Any ideas on what this could be? I notice it most on deceleration just letting off the gas...
Death_Eagle_571 is offline
post #2 of 5 Old 01-10-2010, 04:33 PM Thread Starter
Death_Eagle_571
1976 CJ5
Any Ideas guys?
post #3 of 5 Old 01-10-2010, 07:27 PM
gojeepin
1983 CJ7
Could use more info...
Is everything stock... driveline and suspension?
A new suspension lift could explain the vibration.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #4 of 5 Old 01-10-2010, 07:34 PM
texasimport
1978 CJ5
ditto . . . . with Gojeepin. . . . bet your lifted and have a drive shaft that isn't keeping up with the program. You must keep both ends of the drive shaft at the same angel to transfer case yoke and the rear end to avoid vibration. You only can get away with having rear end pointing to the transfer case, uneven angels, when you are using double cardigan (sp?) driveshaft set up.
78 304-CJ5
texasimport is offline
post #5 of 5 Old 01-10-2010, 09:30 PM Thread Starter
Death_Eagle_571
1976 CJ5
It does have a stock driveline, and a small lift, but this is a new occurring issue, it just started happening a few weeks ago, so I'm 99% certain its not the driveshaft, I wanna think it could be a clutch-related vibration...
Transfer Case Model 20 question kyalbert Jeep CJ Forum 0 02-02-2010 12:26 PM
Model 20 T-case teardown. Major issues attworth Jeep CJ Forum 20 07-29-2009 04:15 PM
Model 20 Transfer Case Shift Pattern BeesJeep Jeep CJ Forum 2 04-25-2009 07:05 AM
What vehicles had the Dana Model 18 transfer case? Blue Mule Jeep CJ Forum 9 07-23-2008 08:35 AM
model 20 transfer case 1pfieffer1 Jeep CJ Forum 8 01-14-2008 08:09 AM
