Vibration after Th400 install. - Page 2 - JeepForum.com
post #16 of 25 Old 08-25-2014, 10:10 AM Thread Starter
skizriz
1978 CJ7
Wonder if its possible it came out stuck to the old converter, or if it didnt have one (the engine looks to be a swap) and it just didnt vibrate with the old TC and FP.
Guess ill have to slide it back and take a peek.
Sent from my HTC One SV using JeepForum
skizriz is online now
post #17 of 25 Old 08-25-2014, 10:19 AM
jblue1555
1979 CJ7
Someone could have had a converter built with a 727 snout to eliminate the need for the ring.
jblue1555 is offline
post #18 of 25 Old 08-25-2014, 04:24 PM Thread Starter
skizriz
1978 CJ7
Here's what I got going on. I have no idea how much wobble is acceptable, but this seems excessive to me. I ran the rpms up to the point of the most vibration.
Here is a shot of it unbolted from the flex plate. I tried to show the movement of me pushing up on it. It is a very small amount, but pushing up on it makes a difference in getting the first bolt started into the TC.
I hate to think it's a crooked TC or flex plate.
post #19 of 25 Old 08-25-2014, 05:19 PM Thread Starter
skizriz
1978 CJ7
A couple more. Doesn't look as bad from directly below.
In this one the 3 TC bolts are only finger tight.
Bolts are tightened back down in this one.
post #20 of 25 Old 08-25-2014, 05:33 PM
jblue1555
1979 CJ7
Should have asked this earlier, you are sure the flexplate is the right one for the engine.
post #21 of 25 Old 08-25-2014, 05:50 PM Thread Starter
skizriz
1978 CJ7
According to the MFG, Pioneer, it is. Pioneer FRA-119 W/O weight. Just checked my records, that's the number Summit sent me. Summit has FRA-108 listed as for the th400,I called Pioneer to make sure on who's number was correct. 108 is for the later years.
Looked identical to the old one.
post #22 of 25 Old 08-25-2014, 06:32 PM
jblue1555
1979 CJ7
Same engine, correct flexplate, vibration, pull it, check for sleeve in crank,double check trans.
post #23 of 25 Old 08-26-2014, 01:14 AM
grasmo
1982 CJ5
I don't see anything unusual there. you didn't by chance do any recent work on the front of the engine did you? if not, and you're sure about the trans. rebuild, I would have to think that converter has a problem. a tc is a fluid coupling and by nature fluid couplings combat vibrations unless it has an internal issue.
grasmo is offline
post #24 of 25 Old 08-26-2014, 11:24 AM
schardein
1983 CJ7
Here is a story:
I took the TH400 out of my 78 K20 and put it in my K5. Years later, I pulled it and took it for rebuild. The rebuilder took one look at it and said, "you'll need a new converter". Why, I ask. "Because your centering washer is gone. Chevy welds a washer to the front of the TH400 torque converter and that is what centers it in the crank. A TH350 simply has a snout that aligns in the crank bore. Look in the back of your crank when you get home". Sure enough, the washer was stuck in there.
I never noticed a vibration before that, but with my driveshaft vibrations, that doesn't mean it wasn't there.
Also I am no expert on AMC TH400... but my guess would be they are the same way.
1983 CJ7, 5.3, NV3550, D300 4:1, Fr D44 Detroit, Rr D44 OX, 4.56, 35" SSTs on beadlocks
schardein is offline
post #25 of 25 Old 08-26-2014, 03:27 PM Thread Starter
skizriz
1978 CJ7
I have plans to go wheeling this weekend, so i wont be tearing it down until after then. Im going to see about exchanging the converter while i have it out also. Hopefully it isnt something inside the trans.
