vibration!!! - JeepForum.com
post #1 of 5 Old 08-29-2002, 07:01 AM Thread Starter
diggy
vibration!!!
Hi, everybody. I just finished my rough country 4", now my 79 cj5 is a death trap, I'm afraid to even drive it around the block. the person at RC told me the pinion angle is built into the spring. I think he is full of it. The vibration is unbearable. it's at all speeds.
Plus the steering is so vague. It will shoot to one side, when i go to correct it, it shoots the other way. Pucker factor of 8 out of 10. I'm instaling the drop pitman and getting it aligned tomorrow. I know know that will help some. I can't imagine it will cure it all. any ideas?
by the way, it's a 79 cj5, 304.with a fiberglass tub and one piese front end. 4" rc lift, 1 inch shackel. and 31" till the savings get a little better. one more guestion, should I go with 33"s or 35"s. I can get BFGs a/t for $90 a piece.
Diggy
diggy is offline
post #2 of 5 Old 08-29-2002, 07:21 PM
NC74CJ
NC74CJ's Avatar
Truth is, which the stock driveshaft you shouldnt change your pinion angle. This is done under the asumption you are running a CV driveshaft, which you will have to do with that kind of lift on a CJ5. I have a milder lift on mine and I was constantly breaking ujoints and even yokes until I got Tom Woods to set me up with a CV shaft (www.4xshaft.com). Completely solved my problems, and its definately a necessity. Good luck
Bill
A stroke bolder, a pinch better.
NC74CJ is offline
post #3 of 5 Old 08-30-2002, 12:14 AM
JIM79CJ7
JIM79CJ7's Avatar
just a thought: did you put degree shims in with the springs ? Also before you have it aligned check your caster angle , the more arch the more caster you lose in most cases .
Just my $.02 ,
JIM :{>
originally posted by Mikeythefireman :
Mr. Bill, you're a Jacka$$! or should I say 'drack you're a Jacka$$ I was looking for a straight answer there.
Custom Stuff---
ORANGE JEEP CLUB
MEMBER # 1
1979 CJ7 / 304 /T 150 /HUGGER ORANGE PAINT JOB/ Lots of cool stuff
2003 Inca Gold Rubicon , <------ Sissy jeep :)
JIM79CJ7 is offline
post #4 of 5 Old 08-30-2002, 06:40 AM Thread Starter
diggy
I'm gonna spend the day checking everything out. I let ya know what I find. wish me luck!
thanks
Diggy
diggy is offline
post #5 of 5 Old 08-30-2002, 08:28 AM
Dodster
Diggy - Check out the short shaft article at www.jeepzine.com. Maybe it will help. Good luck.
1981 CJ-8 SOA 360 V-8 EFI
Dodster is offline
Vibration SavSilvrCJ Jeep CJ Forum 3 11-06-2007 06:01 AM
Odd Vibration Recalcitrant Jeep CJ Forum 7 10-29-2006 07:44 PM
vibration rifed1 Jeep CJ Forum 1 07-23-2005 12:09 PM
Vibration at 35 MPH and up - HELP !!! sbestmann Jeep CJ Forum 6 08-22-2003 05:33 AM
Vibration in 77 CJ-7 habman Jeep CJ Forum 1 06-01-2003 07:20 AM
