Vibrating Mirrors - JeepForum.com
post #1 of 10 Old 07-14-2013, 07:43 AM Thread Starter
gogop66
Vibrating Mirrors
My two sides mirrors vibrate like crazy making them just about useless while at speed. The re-view mirror is fine and I can see clearly. I suppose this is common but just in case I'm wrong does anyone know of a fix or after market mirror that is better? Thanks in advance!
gogop66 is offline
post #2 of 10 Old 07-14-2013, 07:57 AM
keith460
Jeep. There's Only One
keith460's Avatar
The aftermarket mirrors will vibrate more then the OEM ones due to the thin tubing and mounting brackets. Poly body and engine/trans bushings also contribute to unwanted vibrations.
1984 CJ-7 Renegade
keith460 is online now
post #3 of 10 Old 07-14-2013, 09:04 AM
82JeepCJ7
1982 CJ7
Its a Jeep, not a car. They are going to vibrate.
Tire selection has a lot to do with is as well.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #4 of 10 Old 07-14-2013, 10:17 AM
skizriz
1978 CJ7
I hold mine steady with my foot when I'm on the highway. J/K. ;-)
Sent from my HTC One SV using JeepForum
skizriz is offline
post #5 of 10 Old 07-14-2013, 10:44 AM
waterdowg
Keith, are you saying rubber bushing are better for vibration? I'm trying to decide between rubber and poly for my rebuild.
waterdowg is offline
post #6 of 10 Old 07-14-2013, 10:49 AM
PROJECT 23
Mirrors are for looking at things in the past. Look ahead into what's approaching in life and make decisions based upon that. Remove the mirrors and focus. Use the force brother......
LOL, that's part of owning a CJ.
PROJECT 23 is offline
post #7 of 10 Old 07-14-2013, 11:01 AM
Renegade82
1982 CJ7
If you can solve that mirror vibration...... patent the method and prepare to be rich! Seriously though, it's the single support arm design, the weight of the mirror, it's flat backside and the wind velocity.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #8 of 10 Old 07-16-2013, 01:59 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I never expect a clear view from mirrors while moving - wind and vibrations move the side view ones, and the windshield frame moves a lot from wind and vibration for the center rear view mirror to give a clear view. They are clear enough to know if there is someone there or not, and you should be looking back anyways to make sure there is nobody in your blind spots. If you are trying to read license plates or check out something in detail behind you, forget it. You shouldn't be that focused on items behind you anyways.
And yes, poly mounts (engine, body, trans, etc) do transmit more vibes than rubber does. That is why I use rubber mounts. If I wanted to drive a vibrating rattle trap, I'd drive my Ranger with poly motor mounts and no body mounts - the body sits on the frame nowadays from rust taking the mounts out....
Rick
Cutlass327 is offline
post #9 of 10 Old 07-16-2013, 02:06 AM
keith460
keith460's Avatar
Originally Posted by waterdowg View Post
Keith, are you saying rubber bushing are better for dampening vibration? I'm trying to decide between rubber and poly for my rebuild.
Yep, that's what I'm saying as it is a known fact.
1984 CJ-7 Renegade
post #10 of 10 Old 07-16-2013, 03:30 AM
BagusJeep
1981 CJ7
It depends to an extent on which mirrors you have and where they are mounted as there are several styles that POs could have chosen to "make it better".
I have the OEM style windshield hinge mounted mirrors, 5 years old and stainless steel from Qadratech. The PO had put door mounted mirrors on and they were small and dark and pitiful so I ordered some nice big OEM style ones (I then changed to the short fabric doors from Bestop so I would have had to anyway).
Upshot is that they do not vibrate on Bagusjeep and I have a clear view. It may be because the rubbers are fairly new and Bagusjeep rolls well, but also the screws around the ball joint on the end of the arm are in good shape and properly tightened.
Would I buy them again? Yes.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
