vibrates realy bad just in 4x4.... - JeepForum.com
post #1 of 12 Old 05-09-2012, 05:35 PM Thread Starter
chevypowered
1981 CJ7
Hey whenever i put my cj7 in four wheel drive it vibrates really bad at like 5 mph and gets worst the faster i go. Defintally coming from the front. I'm guessing a bent axle shaft??? Its the stock dana 30 in it.
chevypowered is offline
post #2 of 12 Old 05-09-2012, 06:22 PM
SeaWulf
1983 CJ7
Bent front driveshaft, maybe?
SeaWulf is offline
post #3 of 12 Old 05-09-2012, 06:43 PM
skizriz
1978 CJ7
Is it something that just started happening recently??
skizriz is offline
post #4 of 12 Old 05-09-2012, 06:45 PM
wellmax
my old jeep, 1984 cj
the front drive shaft U JOINT was worn out (the u joint that is connected to the transfer case).
have to ask the little neighbor girl to take the bolts out of that u joint, as she will be the only one with a hand small enough to work on the u joint.
also, it takes a special grease gun end to even grease that joint, guess that is why it worn out.
wellmax is offline
post #5 of 12 Old 05-09-2012, 07:18 PM Thread Starter
chevypowered
1981 CJ7
Yes it just started happening. I dont think its a u-joint but i will check them out. How hard is it to bend a axle shaft??? The jeep spends most of its time in the rocks amd mud. Thanks
post #6 of 12 Old 05-09-2012, 07:21 PM
pman
x2^^^^
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
pman is offline
post #7 of 12 Old 05-09-2012, 08:17 PM
86cj74.2L
86cj74.2L's Avatar
The vibes on the 86 in 4 wheel drive was a combination of a bad u-joint on passenger side and a worn slip joint on the front driveshaft.
86cj74.2L is offline
post #8 of 12 Old 05-10-2012, 04:50 AM Thread Starter
chevypowered
1981 CJ7
The slip joint on the front driveshaft i can wiggle all over so I'm guessing thats it. Those very hard to change out?
post #9 of 12 Old 05-10-2012, 08:39 AM
foggybottombob
I never heard of replacing half of a drive shaft. I think you will need to replace your front drive shaft. It has 4 bolts on either end.
foggybottombob is offline
post #10 of 12 Old 05-10-2012, 09:18 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
You can get them rebuilt, just take it to any machine shop that does drive shaft work. They'll cut the old slip yoke off and put a new one on. But check around for a used one first, may be cheaper!
Rick
Cutlass327 is offline
post #11 of 12 Old 05-10-2012, 11:15 AM
twoleos617
ive seen a few for sale in the classifieds lately for around $75
Torque is the measure of force that gets the cap off your beer.
Mike D.
twoleos617 is offline
post #12 of 12 Old 05-10-2012, 08:57 PM Thread Starter
chevypowered
1981 CJ7
i have found a few drive shafts on ebay and craigslist that im going to look into. put the jeep on the lift this afternoon to give everything a good look over and found that the passenger side u-joint was bad as well. got everything apart and axle pulled out. gunna get parts tomorrow and get her back in the woods hopfully.
