VERY confused, please help me. ;( -- timing/carb issues - JeepForum.com
post #1 of 10 Old 03-01-2008, 03:52 PM Thread Starter
mmerlina
Image Glassworks, Inc.
mmerlina's Avatar
Hey everyone, I've read my book so many times, I just can't figure this out and it's driving me NUTS! I'm trying to initially run the engine, it's never been configured before. I followed my manual on how to find TDC, and I did that, I got the distributor in. Now my mc2100 has just been rebuilt, so it's not tuned for anything.. it's just there.
When I fire it up, it runs like garbage, I have to keep it at like 1500 rpm to get it to run steady. Around 1000 it starts shaking a bit. Now I don't know if I'm supposed to be trying to time it, or figure out the carb. How do you do both?
When I mess around with the idle screws on the carb, it changes my timing, then if I go to time it.. it messes with the way it's idling. I'm lost. ;/ Please help.
I don't know if this is relevant but.. when I swapped motors I never took the distributor apart, I just marked all the plugs and slid it out.
Mike
1986 Jeep CJ7 (
Remanufactured 258, ARB lockers front & rear, 4.10 Yukon gears, 35x12.5" Super Swamper SSR's, Motorcraft 2100, 4.5" Rubicon Express Extreme-Duty lift, York 210 OBA, Big Daddy steering, Tatton rear CV driveshaft, Herculined interior, TJ flares, lots of body & upholstery work
mmerlina is offline
post #2 of 10 Old 03-01-2008, 04:10 PM
CJClyde
If it were mine, I would try to find the timing first. If you can get someone to keep it running while you use a light to find the time, the carb will be much easier to tune after that. Where is your timing now?
1984 CJ-7, 4" Trailmaster, 31's. Future plans include complete rebuild with SBC 350, Dana 44 front, Ford 9 inch rear, and SOA with highsteer.
CJClyde is offline
post #3 of 10 Old 03-01-2008, 04:23 PM Thread Starter
mmerlina
mmerlina's Avatar
Well if someone keeps it running with their foot on the gas.. the timing jumps around depending on how open/closed they keep the carb. I watch that white line jump around and I'm so confused on how the heck to do this.
Mike
1986 Jeep CJ7 (
mmerlina is offline
post #4 of 10 Old 03-01-2008, 08:05 PM
slacker92104
slacker92104's Avatar
I found that I had to keep tinkering with the two. Make an adjustment to one then to the other again and again a couple of times. It's a matter really of getting the carb adjusted well enough for the motor to run at the specified idle speed. Then you can do the final timing adjustments.
The reason the timing changes when the rpms change is because of the advance.
'81 CJ5, efi 302, AX-15 5 spd, On Board Air, wrangler spring conversion, Astro van Hydro Brakes.
Soon: Custom cut Dana 44 front, wide trac solid axle amc 20 rear, SOA,
slacker92104 is offline
post #5 of 10 Old 03-01-2008, 08:19 PM
bigyearn
1975 CJ5
do you have your carb set to "FACTORY NEEDLE SETTINGS"?
I would start from there and try to get it running first.
unless your timing is so far of it will not want to run.
bigyearn is offline
post #6 of 10 Old 03-01-2008, 08:29 PM
bdmonist
WTF is that?
bdmonist's Avatar
If the timing is not even close enough to keep it running, I would suggest the timing be set first, such as CJClyde recommended. If it runs, just rough - then you may want to adjust the carb. can you disconnect the computer setting or whatever is changing your time when you adjust the carb? If so, do that, set your time, then reconnect and go back and set your carb. I am unfamilair with your carb, if I am way off I apologize.
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline
post #7 of 10 Old 03-01-2008, 08:50 PM
Indy
Indy's Avatar
Timing and carb adjustment are not related to each other. You're seeing the timing mark jump around not because the timing is moving around, but because the cylinder is mis-firing. Odds are you're off by a tooth on the distributor. I'd get back to TDC on #1, pull and re-install the distributor.
I'm the only gay eskimo.
Indy is offline
post #8 of 10 Old 03-02-2008, 07:47 AM Thread Starter
mmerlina
mmerlina's Avatar
Okay guys, thank you all for the replies, I got it running last night and when I got home I just went right to bed!
slacker, what I did was adjust the carb mixture screws first so it actually ran, and then tweaked it to idle at 800rpm (roughly). Then I timed it.. and it smoothed out. Before I was trying to run back and forth and get it to run smooth while tinkering with both, and that doesn't work.. so I learned something!
bigyearn, I put a motorcraft 2100 on so I can't use any factory specs when it comes to the carb. ;/
bdmonst, I ripped the computer out when I did the nutter and put the mc2100 on. I believe what was changing the time was the advanced, like slacker says..
Indy, that was recommended to me by someone that was with me.. we did do that but it was good!
Thank you guys very much for all the input! Everyone was very helpful! I finally got 'er running!
Mike
1986 Jeep CJ7 (
mmerlina is offline
post #9 of 10 Old 03-02-2008, 11:33 AM
Indy
Indy's Avatar
It always feels good when you fix a problem that's driving you nuts. I just did a carb swap and had bad idle/stalling problems... sometimes. Then it would idle great, then it it idle high, then it would bog and die... Spent 2 days trying to track a vacuum leak or anything else that would cause it. Turned out I had a tiny bit of crap floating around inside my idle jet. Sometimes it would flow, sometimes it would block. Got it out and she idles and runs like a dream. Took all of 5 seconds to fix.
Indy is offline
post #10 of 10 Old 03-02-2008, 07:46 PM Thread Starter
mmerlina
mmerlina's Avatar
Hehe, congrats on fixing that! That sounds to be very annoying.. it's always nice when it turns out to be something small though, isn't it?
Mike
1986 Jeep CJ7 (
mmerlina is offline
258 timing, carb tuning help Seether Jeep CJ Forum 9 07-21-2010 06:16 PM
Carb/Timing Tuning kappa505 Jeep CJ Forum 12 12-13-2009 09:58 AM
Confused about timing marks Matt in TN Jeep CJ Forum 4 03-27-2007 08:24 AM
Timing or Carb? jelmore Jeep CJ Forum 11 03-11-2007 08:45 AM
Weber carb issues...Carb backfiring cjthor Jeep CJ Forum 1 10-15-2004 12:34 PM
