Vapor locked - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Vapor locked
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineZone Offroad Body and Suspension Lift Kits, Brackets, DiscBilstein Shock Upgrade Kits, Jeep JK TJ XJ Wranglers and C
Unread 07-26-2014, 06:12 PM   #1
little79cj
little79cj's Avatar
1979 CJ5
Vapor locked
Been goin through this recently in this wonderful louisiana heat and askin for suggestions on how to combat it. I've got some hood louvers on the way and I was lookin for anything else to help when I thought " hey i'm sure somebody tried puttin their gas in the fridge before", found fuel coolers, and am wondering if its a good idea or just too much money/effort to be worth it.
little79cj is offline   Reply With Quote
Unread 07-26-2014, 06:28 PM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
What engine? If you have a stock gas filter installed level with the right side up with the return line at the top you can't get vapour lock.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is online now   Reply With Quote
Unread 07-26-2014, 06:30 PM   #3
little79cj
little79cj's Avatar
1979 CJ5
258. ill post a pic just for simplicity sake
Unread 07-26-2014, 06:44 PM   #4
little79cj
little79cj's Avatar
1979 CJ5
I did not know they had to be level. well i guess my question has been answered.
Unread 07-26-2014, 06:50 PM   #5
little79cj
little79cj's Avatar
1979 CJ5
So is the return line in the right place I just need to get the filter level? Also I apologize for the sideways pic dont know how to get em right side up yet.
Unread 07-26-2014, 06:52 PM   #6
wellmax
I would raise the fuel filter up some.
here are some old school methods of dealing with vapor locking.
do not know if any would help you, but they did not cost you anything.
__________________________________________________ __________
1st..be sure its not vapor locking in the fuel lines...are the fuel lines close to the exhaust manifold or engine block for too long of a run?
2nd..a heat sink under the carb can help..and a non metalic spacer to move the carb up off the manifold some..
I have seen where guys will machine a thin aluminum plate to go under the carb to disapate the heat
I have also seen a number of clothes pins added to a fuel line to disapate heat..and tin foil on fuel lines..the list goes on
also check your timing, an engine out of time will run hotter!!!!!!
do you have the fan shroud around the fan, this shroud direct air through the radiator and helps keep the motor cooler, if you have an fan clutch it could be defective and letting your engine get hotter.
just a couple of items to look at. are you running anti freeze or just straight water in cooling system?
wellmax is offline   Reply With Quote
Unread 07-26-2014, 07:00 PM   #7
little79cj
little79cj's Avatar
1979 CJ5
Check on the raising of the filter. The fuel return line basically sits on top of the exhaust, so i've been suspicious of this raising the temp of the fuel in the tank. I do need to invest in a fan shroud. Using coolant 50/50.
Unread 07-26-2014, 07:13 PM   #8
little79cj
little79cj's Avatar
1979 CJ5
Is the return line resting on/near exhaust sufficient enough to eventually cause vapor lock? Sandy(the jeep) runs perfectly fine for about the first hour then she starts hiccuping and stuttering. Usually when im sitting still or driving slowly. Highway driving and cool weather runs like a dream.
Unread 07-27-2014, 05:14 AM   #9
Mike Romain
Yes if the return is too close to the exhaust it can cause vapour in the wrong place. It usually just drops down a little, then scoots over close to the wheel well. Same deal with the input line being higher than the return line, vapour can collect there rather than get blown off the back top corner to the return.
Mike
Unread 07-27-2014, 07:40 AM   #10
little79cj
little79cj's Avatar
1979 CJ5
Ok. Thanks for the help guys. Gotta wait for the next paycheck before I can implement these controls.
79 CJ5 - Sandy
87 Cherokee - Onion
Unread 07-27-2014, 08:45 AM   #11
hutch1200
hutch1200's Avatar
1979 CJ7
Vented gas cap? On really hot days I swipe 1/2 bags of ice from the outside freezers for the Air Gap intake
The only "FINISHED CJ" is the stripped one in a junkyard w/a bent frame.
hutch1200 is offline   Reply With Quote
Unread 07-27-2014, 09:32 AM   #12
little79cj
little79cj's Avatar
1979 CJ5
Yes I invested in the vented gas cap when I was on my way down to florida on leave when I heard pangs and booms comin from the back of the jeep. Scared the bujeezus outta me.
Unread 07-27-2014, 09:49 AM   #13
little79cj
little79cj's Avatar
1979 CJ5
I think id be a little scared to throw a bag of ice on a hot engine personally. Unless you prefer cube by cube. Has anyone here tried an electric fan setup and if so how much better is it than just mechanical fan?
Unread 08-01-2014, 09:24 PM   #14
little79cj
little79cj's Avatar
1979 CJ5
I have been payed, so controls are being implemented. Does this look a little better mike?
79 CJ5 - Sandy
87 Cherokee - Onion
Unread 08-01-2014, 09:58 PM   #15
19jeep85
Looks better, make sure your canister filter is not plugged up too. The purpose of the return line filter is to prevent vapor lock, in a single inlet/outlet line; heat boils the gas creating an air pocket (vapor lock) so fuel doesn't flow. The return line allows the vaporization to return back to the tank where it turns back to a liquid. Check that the return line also isn't plugged.
“ The heart of the wise inclines to the right, but the heart of the fool to the left .”
19jeep85 is online now   Reply With Quote
