Valve cover upgrade on 83cj7 258 - JeepForum.com
post #1 of 8 Old 09-18-2012, 09:15 PM Thread Starter
steelechris
Can't get this crappy plastic valve cover to seal and I'm definitely tired of smelling like burnt oil every time I drive. I'm thinking about changing out the plastic valve cover to aluminum but I'm definitely not very mechanically inclined. Ha. I can usually figure most things out but I'm kinda nervous about drilling holes in my motor. Any advice that y'all could lend would be greatly appreciated!!
steelechris is offline
post #2 of 8 Old 09-19-2012, 09:33 AM
wm69
You probably won't have to drill any holes. On my 85's the holes were all there, I just had to tap two of them on the driver's side of the engine. I went and got shorter bolts rather than drilling the holes deeper, because I was worried about drilling into the water jacket. Been on there since 2002 and not leaking a drop.
I'd take the plastic one off and look before you get too excited though. 258 heads were different over the years, and some had the holes there and some didn't.
Should be the stock mounting bolts on the passenger side of the engine and the front and rear of the engine, and then two holes on the drivers side. IIRC I ended up buying all new bolts because the ones supplied with my "4.2" valve cover weren't the right size, but all I had to do was tap the two holes on the driver's side and it bolted right up.
wm69 is online now
post #3 of 8 Old 09-19-2012, 03:27 PM
248107
1983 CJ7
You'll also have to deal with the bolts coming up thru the cover off the rocker arms.They sell a kit to adapt them.I think some people saw them off but not sure.Maybe someone will chime in on this.I've got one i'm going to put on.I have the instructions if you want me to PM them to you.
248107 is offline
post #4 of 8 Old 09-19-2012, 09:55 PM Thread Starter
steelechris
Thanks for the advice! Hopefully it will go easier than expected.
post #5 of 8 Old 06-05-2014, 06:20 PM
munypit
Do you have to buy the rocker arm upgrade or can you just cut them off?
munypit is offline
post #6 of 8 Old 06-05-2014, 11:23 PM
BubbaK
1983 CJ7
The Crown aluminum cover comes with the alternate rocker bridges, but I've "heard" that since the aftermarket valve cover is taller, it clears the OEM studs.
'83 CJ-7_258 I-6_T-4_D300_AMC20/D30_Bone Stock
BubbaK is offline
post #7 of 8 Old 06-06-2014, 05:37 AM
Mike Romain
My last install of the plastic cover was leak free for years. I use a plain cork gasket, the ones with the metal core never work (metal gets the slightest bend in it in shipping and never lays flat again) and those expensive rubber ones are garbage.
I washed my cover in a tub of soapy water and cleaned the head mating surface really well. They both got a spray of brake cleaner to be sure there was no grease.
Next I put a skim of sensor safe black permatex RTV on the head, put the cork gasket down and put a skim of RTV on the gasket, then I put the valve cover on and torqued the bolts down immediately like the permatex directions say to do. I then walked away for the 24 hour cure time permatex calls for and was leak free until I stepped on it by mistake 7 or 8 years later trying to fix a light in my one piece front flip clip.
Mike
Mike Romain is offline
post #8 of 8 Old 06-06-2014, 07:56 AM
tfireguy
I purchased my aluminum cover from parts train. It came with a extra thick cork gasket. I just had to tape two hole that are already in the head. Cost for cover was 94.00
tfireguy is offline
