Valve Cover Troubles - Page 3 - JeepForum.com
post #31 of 37 Old 01-27-2012, 02:07 PM
gmgreen
1983 CJ7
Thanks Keith, seems like everybody has their own way of doing things. It's taken about 4-5 hours getting off the old gasket and making sure everything is clean. Headed to AZ to get some scotchbrite pads and some brake cleaner to make sure everything is clean. Wish me luck I'm getting ready to bottom tap the bolt holes. I've never done anything like this before and it makes you feel good and I probably saved some money in the mean time.
gmgreen is offline
post #32 of 37 Old 01-27-2012, 06:07 PM
keith460
Jeep. There's Only One
keith460's Avatar
A word of caution if one is to drill and tap while the cylinder head is still on the engine. Have a shop vac or household vacuum cleaner with the hose attached and pulling chips away as you tap and drill. Greatly reduces the chance of having unwanted foreign material fall into the oil passage ways of the cylinder head.
1984 CJ-7 Renegade
keith460 is offline
post #33 of 37 Old 02-09-2012, 10:04 PM Thread Starter
KidLoco747
Well, fellas, finally got the the new aluminum valve cover on using the allen head bolts! Oh yeah, jacking up the transfer case was the trick that helped the valve cover clear the fire wall! Thanks for all the help and feedback.
KidLoco747 is offline
post #34 of 37 Old 02-10-2012, 05:46 AM
gmgreen
1983 CJ7
Originally Posted by KidLoco747 View Post
Well, fellas, finally got the the new aluminum valve cover on using the allen head bolts! Thanks for all the help and feedback.
I got mine on too but it leaks! What kind of gasket and sealant did you end up using?
gmgreen is offline
post #35 of 37 Old 02-16-2012, 06:17 PM Thread Starter
KidLoco747
I used the gasket that came with the valve cover and used "Permatex, 1 Minute Gasket" sealant (item #25229). No leaks so far!
post #36 of 37 Old 02-16-2012, 06:55 PM
gmgreen
1983 CJ7
Dropping it off at the shop so someone besides me can get my VC on without it leaking. I'm bummed out I couldn't get it right myself.
gmgreen is offline
post #37 of 37 Old 02-16-2012, 07:08 PM
DVR
Try again. The aluminum cover takes a specific gasket and the part number comes with the kit. For those who mentioned different bolts- The current crown kit includes allen head bolts.
I put indian head gasket shellac on the cover and the cover side of the gasket, let it dry pretty good, put the gasket and cover together, put grease on the head side of the cover and it sealed up nice.
I tried it with grease on both sides and it didn't seal at all in the half moon cutouts on the drivers side.
DVR is offline
Changing valve cover gaskets/valve covers gtrpup2 Jeep CJ Forum 20 03-28-2013 07:35 PM
PCV Valve install in 4.0 Valve Cover? VaCJ79 Jeep CJ Forum 5 10-24-2010 11:14 AM
PCV Valve location/Valve cover replacement jobst Jeep CJ Forum 2 03-28-2010 01:53 PM
PCV valve and leaking valve cover hole crrushing Jeep CJ Forum 2 02-08-2010 05:44 AM
Timing Chain Cover Seal Troubles johnny_d Jeep CJ Forum 7 10-18-2006 11:48 PM
