Valve cover remove SURPRISE! - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Valve cover remove SURPRISE!
Spartan Locker's at all time LOW exclusive from ROCKRIDGE FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Bds fox ipf 2.0 racing series shocks now available at rock
Unread 05-15-2015, 06:20 AM   #1
STJP
Street Jeep
STJP's Avatar
Cleaned up much of the crud on the driver side if the engine. The plastic valve cover may have been weeping for some time near rear on that side. I found the rear bolt missing and the one on the driver side nearest the firewall was loose. Removed the valve cover and this is the mess I found.
I am no engine expert, but this can't mean anything good. Would appreciate information re what would cause this and what to do about it.
I purchased this CJ 10 years ago and have driven it VERY little. What little I've driven it showed no engine issues. No smoke etc. From the day I've had it, have used top of the line full synthetic oil.
Thanks, STJP
STJP is offline   Reply With Quote Quick reply to this message
Unread 05-15-2015, 06:31 AM   #2
Jim1611
Jim1611's Avatar
I've seen guys empty all the oil then fill it back up with diesel fuel then let it run long enough to start warming up to clean junk like that up. I never saw any ill affects from it either. However you try to clean it up I'd for sure replace the oil pump.
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 05-15-2015, 06:44 AM   #3
STJP
Street Jeep
STJP's Avatar
Thanks for your post. I'd hate to risk pumping all that crud through the engine. No telling what the inside of the crankcase looks like too.
Do you think this is the result of cheap oil and high temps?
This really discouraging. I am just about ready to re-install my manifolds with a new Weber 38 as well as several other upgrades like a new cast aluminum valve cover. I can't just put a new valve cover over this mess. Maybe I should remove the head and have it reworked etc.
STJP
Unread 05-15-2015, 06:47 AM   #4
Mortgage-payer
1976 CJ7
I found the remains of a dead mouse under my valve cover...
While that looks like a lot of crap, keep in mind it is not where the wear parts of the engine slide against each other.
Get a metal valve cover and follow the numerous threads here on installing it.
Then run a diesel engine oil like Shell Rotella which has higher detergent levels.
The only thing that should go in a oil pan is oil.
I call it a distributor, not a dizzy.
Mortgage-payer is offline   Reply With Quote Quick reply to this message
Unread 05-15-2015, 06:51 AM   #5
turkish6
1982 CJ8
I'm far from an expert but since your manifolds are already off... There's not much left to remove the head.
turkish6 is offline   Reply With Quote Quick reply to this message
Unread 05-15-2015, 06:51 AM   #6
Mortgage-payer
1976 CJ7
A good quality filter will catch anything before it can do any harm.
I buy Baldwin B39's by the case at Zoro.
Stay away from the orange cans of engine death.
Unread 05-15-2015, 08:03 AM   #7
jblue1555
1979 CJ7
That's usually from poor oil change practices and engine temps to low, short trips, no thermostat
jblue1555 is offline   Reply With Quote Quick reply to this message
Unread 05-15-2015, 08:22 AM   #8
thirstybob
From my experience, the sludge accumulates due to infrequent oil changes.
thirstybob is offline   Reply With Quote Quick reply to this message
Unread 05-15-2015, 08:35 AM   #9
ColdSteel85
1982 CJ7
While cleaning up under the hood and fixing an exhaust leak I ended up deciding to tear things apart to really clean them. When I removed the plastic valve cover this is how mine looked. Decided while I was at it to change head gasket. I removed the head and called a machine shop. For $65 they are going to clean, polish, and do valve job. That's money well spent in my book. Waiting to go pick it up next week.
ColdSteel85 is offline   Reply With Quote Quick reply to this message
Unread 05-15-2015, 08:47 AM   #10
STJP
Street Jeep
STJP's Avatar
Thank you all. I learn, I learn...as good and cost effective the clean with oil detergents methods are, I am incapable (anal) of putting s valve cover over that. I think the head remove and valve job route may be the way.
Unread 05-15-2015, 08:51 AM   #11
duffer
1955 CJ3B
2x on the oil. Back in the 50's and 60's, just about every engine out there looked like that. I would not run diesel in it but rather do about 3 engine oil changes at 500 miles with high detergent oil and perhaps with Seafoam-changing the filter each time. I use Wix filters on just about everything I own.
I can see zero use disassembling anything as long as it is running well. Frankly, it could probably go another 100k looking like that with no ill effects.
1955 CJ 3B, 381cid sbc (441cid all aluminum sbc coming soon), AGE M22W, Teralows, Warn OD, OBA, Premier Power welder, Warn 8274
1968 CJ 5, factory 225" w/ headers/450 cfm Holley, T86AA, Belleview winch, Warn OD
2012 Wrangler Rubicon Unlimited, Warn 9.5 xp-s winch
duffer is offline   Reply With Quote Quick reply to this message
Unread 05-15-2015, 10:13 AM   #12
Splinter
1980 CJ5
My guess as well
Splinter is offline   Reply With Quote Quick reply to this message
Unread 05-15-2015, 10:22 AM   #13
80cj
80cj's Avatar
1980 CJ5
I have a friend who bought a used Jeep Cherokee a few years ago. The engine was sludged up worse than the OP's. He pulled the valve cover and removed what sludge he could then ran Chevron Delo 400 in it. His changed oil and filters at short intervals for a while. After 1000 miles, the engine really quieted down and looked a lot cleaner. The gas mileage improved noticeably too.
80cj is offline   Reply With Quote Quick reply to this message
Unread 05-15-2015, 10:37 AM   #14
RenoF250
I am anal as well but do not waste your time with that. It is not hurting anything and the rest of the engine is just as dirty so you have not really accomplished anything.
Get some good oil filters and some cheap good oil like Mobil 5000 from Wal-Mart. Run the oil with 4.5 quarts oil, quart of ATF, and 1/2 quart of Marvel Mystery oil. Take some decent length drives and change the oil when it looks dirty. Depending on how hard that is to get off the oil may get filthy in the first 50 miles. Just keep changing until it is clean.
I always look in the valve cover when buying a vehicle to check for this sort of thing. You can usually see this sort of junk on the dipstick and oil cap as well. My engines are all spotless inside, no brown gunk and I always run whatever oil is SN and cheap.
1985 CJ7 with 1994 4.0, AMC20 4.10
2001 TJ 4.0 Dana 44 3.73
RenoF250 is offline   Reply With Quote Quick reply to this message
Unread 05-15-2015, 10:42 AM   #15
billiebob
I'd do this but change the filter first and change it again when you put oil in.
My Uncles first Jeep was a Government Issued Jeep in 1944.
Back when ALL Jeeps were Government Issued.
billiebob is offline   Reply With Quote Quick reply to this message
