Valve cover leak fixin - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Valve cover leak fixin
TJ Dana 60 - BOLT IN REARSpartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEBds fox ipf 2.0 racing series shocks now available at rock
Unread 06-13-2008, 09:06 AM   #1
EtownCJ5
1982 CJ5
Ok, I'm going to tackle this this weekend. I have two fel pro cork gaskets (one for spare) and RTV. Going to clean real good per Mike Romain's advice, let the RTV cure for 24 hours, etc.
I have a question. What is the recommended torque value on the cover bolts? I don't want to gorilla these things and mess it up.
Of course oil change along with this. I'm going with 10w 30 Rotella. What's the best filter to use? Delco, Fram, ?
Appreciate it!
EtownCJ5 is offline   Reply With Quote
Unread 06-13-2008, 10:32 AM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
The latest generation of Fram filters are a failure, they let the engine empty out of oil overnight causing 'bad' start up noises with a dry start (0 on the mechanical oil pressure gauge).
My plastic cover only has the two rocker bridge nuts holding it on and I believe they were 9 inch pounds or something like that. I basically use a 1/4" drive socket wrench held with my thumb and first finger with my baby finger only doing the turning.
It is really important to do them in the pattern called for, just like head bolts for pattern if you have rim bolts and 'really' gently alternating on the two top ones if you have those. I do them more than one time around, all with wet RTV as per the RTV directions on the package.
If you have an O2 sensor, make sure you get 'sensor safe' RTV. The regular stuff will kill the O2 faster than 'you' can smell it coming almost. Permatex calls this the 'Ultra' line I think..
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Unread 06-13-2008, 12:11 PM   #3
bdeck
1983 CJ7
a year ago i tried everything to get mine to quit leaking till finally i broke down and bought a rubber gasket and it solved all my problems. mine cost around $30 but no rtv, and they're re-usable. I'm currently rebuilding my engine and i just put the valve cover back on same rubber gasket and the manuel said around 15 in-lbs
83 CJ-7 258 Renegade
bdeck is offline   Reply With Quote
Unread 06-13-2008, 01:11 PM   #4
my73CJ
1973 CJ5
for my 304 I got the rubber gasket, RTV's it to the valve cover, the outer edge and then wiped a little oil all around the edge, like you do for an oil filter and then tightend the valve cover down. Made sure i had fixed the valve cover as the PO had tightend it down and bent the cover. I didn't measure the torque just went tight w/l defoming the cover, no leaks as of yet
my73CJ is offline   Reply With Quote
