#1 | |
Valve cover issues?
I have a straight 6 and I have changed the valve cover 4 times to try to stop it from leaking but no luck. Does anyone have any ideas? Thinking of buying an aluminum valve cover but i have to tap the head.
#2 |
You have a leaking valve cover , what type of gasket are you using? Are you using rtv, or a sealant, on one or both sides? Do you have a (bridge )or 2 nuts on top of you valve cover?
Do you have the "factory" funny nuts that hold down the cover? hahahahha " Funny nuts"? |
#3 |
I had read somewhere the other day that Clifford makes a nice valve cover for the 258. May look into that myself. Just passing on what I recently read. No first hand experience, but something you might look further into.
#4 |
Don't use gaskets, use RTV, the engine sealant from Chrysler works best, clean both surfaces very well, with brake clean or acetone. Put a good size bead on the cover and bolt it down, let it sit overnight. Mine has been leak free for 8 years after doing it this way.
Always bring a compass, it is embarassing to have to eat your friends. |
#5 | ||
#6 | |
don't waste any more time or money- tapping the head is nothing to be afraid of, and a good aluminum valve cover can be had for well under $100 shipped to your door. there are VERY good write-ups and tips to be found here on JF, as many many of us have done the swap and had good results
http://www.jeepforum.com/forum/f8/new-valve-cover-installled-394824/ http://www.jeepforum.com/forum/f8/new-valve-cover-install-follow-up-400239/ Hoss
Don't mind me, I'm just another FNG around here...
#7 |
OIIIIO
Check to see if the cover is warped.
'85 CJ7, BDS 4" lift, 1" Body lift, 33x12.5, Shrockworks Sliders, 304 V8 with RV cam., T-176, D300, Dana 30, AMC 20. 1986 CJ10-A SD-33 Diesel/727/np208 1971 800B with 345/T-19 88' Comanche, 4.0L F.I., 5 spd. |
#8 |
I'm actually of the opposite. When I use cork gaskets I do not use ANY RTV at all, and have no problems. Overtightening the bolts will pinch the cork gasket and make them leak really bad. A lot of people don't realize that with cork gaskets you can't tighten it too much. Most of the time people will see it leaking and tighten the crap out of the bolts, therefore making it leak 10X as bad...
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress) 1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress) |
#9 | |
I replaced the plastic valve cover with an aluminum one as well. It looks much better and tapping the head is not a big deal. Make sure that you have a bottom tap. I went to Lowe's and bought a regular tap and made my own bottom tap. Also, don't tap to deep or else you'll hit the water jacket. |
#10 |
The "4.2" logoed cover is the same as the "Jeep" logoed cover, which is just as good as the Clifford head cover. I have one of each and none of them leak.
The directions say to drill the two holes on the driver's side of the engine, then tap the holes. I didn't drill on mine, just went and bought shorter bolts. Tapping the holes is about as hard as screwing a rusty bolt down into a hole. Turn clockwise, back off, oil, turn clockwise, back off, oil, repeat. Not a hard job, and well worth it. The plastic valve covers just suck. The one on our Scrambler leaked the day we drove it off the lot when it was brand new.
85 CJ7 258, borla header, jacobs ign, weber carb,optima batt, 135 amp alt, agr super box 2 & pump, T5 w/ B&M shifter, centerforce 2, superior 1 piece axles, warn hubs/ XD8000i, 2.5 in lift, 31" BFG MT 85 CJ7 "wife's ride" 258, A/C, T176, superwinch hubs, 3in lift 31" BFG AT/KO |
#11 | |
WAY TOO FAT FOR MY CJ5
I have both the clifford and the 4.2 logo cover. The 4.2 cover is better in my opinion.
![]() Jeff
1979 CJ5 1978 Cherokee Chief CJ5 Dream/Build Sheet Cherokee Chief Dream/Build Sheet Our SBC Swap How we made a Fan Shroud |
#12 |
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
The big trick is to have them super clean. I also have only the two top rocker nuts holding on my plastic cover and was leak free for 8 years. I coat both sides of a cork gasket with a skim of RTV and then set it in place 'immediately' like the RTV directions say, then wait the 24 hours the directions call for to cure it before going near it, That works,
On this one I did a couple days ago, I had to use a gasket maker glue instead of RTV because it is -20 out and even with my 25,000 BTU heater I can't get the snow to melt inside my tent over the Jeep in the driveway so used somenthing that says it can handle the extreme cold and hopefully set...
Mike 86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10) |
#13 |
My aluminum cover directions said to drill and tap all but the two end 1/4-20s to 5/16-18. I did'nt I used the existing 1/4-20s with pan head ss bolts. The heads are wider than the allen head bolts. The two on the drivers side are 5/16-18. Use a good torqe wrench 50inch/pounds I beleave it was. After an hour or so go over them again and again.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
