Vacuum leak?? Now what?? - JeepForum.com
post #1 of 16 Old 01-18-2007, 10:29 AM Thread Starter
dblock16
With the help of this board I think the loud loud whistle noise Im experiencing is some kind of vacuum leak. I have no idea what to do about it though. I realy need to solve this problem, it makes driving my jeep miserable. Should I take it to a mechanic?
Thanks
DOug
dblock16 is offline
post #2 of 16 Old 01-18-2007, 10:48 AM
ttrem
I would suggest looking at the air hose coming from your PVC to the carb, then just doing a check with the engine running. ( pleases stay away from the fan ) I think most of the vac lines are going to be near your brake reservoir, so you could take a spray bottle and shoot a mist of water on the lines and see if you can see any bubbling. If you do then you found the leak. After that all you need to do is go to the autoparts store and tell em you need some vacuum hose.
If you cannt find it that way, then perhaps someone can suggest something else.
1986 CJ-7 w/ 4.0HO FI, 4" lift, 1" body lift on 35" Super Swampers, AX-15, and a girly sounding horn =(
ttrem is offline
post #3 of 16 Old 01-18-2007, 10:51 AM
JoonHoss
2011 JK Wrangler
Actually, with a vacuum leak, you won't see any bubbling.
use some carb cleaner, and listen for a change in RPM's.
if it's a big leak, you may be able to track it down by sound. try taking a piece of tubing, put one end to your ear, and move the other around, and listen for the whistle.
this may help you narrow down search area.
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is online now
post #4 of 16 Old 01-18-2007, 01:19 PM
ttrem
Hoss
err maybe I was was remembering someones description to finding another problem. SOrry to the OP, after actually thinking it through the leak would be sucking so the water would get sucked in, thus not bubbling. This is gonig to drive me crazy trying to remeber what I was told to do that for.
ttrem is offline
post #5 of 16 Old 01-18-2007, 01:37 PM
JoonHoss
2011 JK Wrangler
Originally Posted by ttrem
This is going to drive me crazy trying to remeber what I was told to do that for.
leaks in a tire...
Hoss
post #6 of 16 Old 01-18-2007, 01:41 PM
biblicone
or exhaust leaks
biblicone is offline
post #7 of 16 Old 01-18-2007, 01:44 PM
JoonHoss
2011 JK Wrangler
^^ true
also, if you were to manage to get water in through a vacuum leak, it would cause then engine to smoke, (much like using seafoam) for a bit, while it burned out the carbon.
Hoss
post #8 of 16 Old 01-18-2007, 03:20 PM
ttrem
Originally Posted by biblicone
or exhaust leaks
that was it.
ttrem is offline
post #9 of 16 Old 01-18-2007, 03:47 PM
danlanphear
1983 CJ7
I have occasionally had problems with cheaper vacuum hoses collapsing under vacuum pressure and creating a squealing sound from inside. It's sort of like the sound you get when you deflate a balloon and the air makes the end of the balloon whistle like a reed.
If you sort of bend the hoses around a bit, you may find one that is sucked shut inside, but opens up again when the engine is off.
Just replace it with a better quality hose, and make sure it's not touching anything real hot.
$0.02
danlanphear is offline
post #10 of 16 Old 01-18-2007, 08:06 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
when do you get this noise? Driving? Idle? 1/2 throttle? Can you make it come and go with the gas pedal while driving?
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
post #11 of 16 Old 01-18-2007, 08:16 PM Thread Starter
dblock16
Ive posted about this noise before and everyone started giving feedback and info on vacuum leaks but thats all over my head.
The niose is very loud, happens sometimes when idling, and sometimes when I let off the gas and pull up to a red light. If i punch the gas in nuetral sometimes I can get it to stop.
It sounds like it is coming from the back end of the engine, but I can't be sure.
So any suggestions?
Thanks
Doug
dblock16 is offline
post #12 of 16 Old 01-18-2007, 09:23 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
does it get louder or go away if you press the brakes?Thats if you have power brakes..
:hahaha: yj
post #13 of 16 Old 01-18-2007, 10:09 PM Thread Starter
dblock16
The brakes nor clutch seem to have no effect on the noise?????
dblock16 is offline
post #14 of 16 Old 01-18-2007, 10:23 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
after its warmed up.Pull the filter off and wile running cup your hand over the top of the carb..not completely closing the venturies off but close,say1/2 inch..see if the idle raises or wants to die..thats a easy way to tell if its indeed a vacume leak..
:hahaha: yj
post #15 of 16 Old 01-18-2007, 10:48 PM Thread Starter
dblock16
Scrambled, thanks I will try that tommorow, Im replacing my power steering pump.
THanks
DOug
dblock16 is offline
Vacuum leak? motojoe Jeep CJ Forum 10 06-01-2007 09:30 PM
vacuum leak dblock16 Jeep CJ Forum 1 02-17-2007 10:01 PM
Vacuum leak? Skrappi69 Jeep CJ Forum 1 03-19-2006 11:37 AM
vacuum leak??? MudMonster Jeep CJ Forum 4 07-23-2004 11:03 PM
82 CJ7 vacuum leak. alexvbugman Jeep CJ Forum 1 03-18-2002 03:41 PM
