Vacuum leak? - JeepForum.com
post #1 of 11 Old 05-29-2007, 06:22 AM Thread Starter
motojoe
1982 CJ7
Vacuum leak?
Could a weak power booster(brakes) cause a vacuum leak? My idle is low due to a vacuum leak. I can close the choke plate to almost closed and it idles fine. That to me indicates a lean running condition. There for I think I have a vacuum leak.
My brakes have been weak and require more foot pressure to apply them. I want to swap out the BBD carb for a MC2100, which I have already. But before I do I want to solve the vacuum problem. I have sprayed around every place I could with choke/carb cleaner to see where the leak is coming from(vacuum hoses, manifold, carb base etc...). All the vacuum hoses are in good condition. Any suggestions?
Motojoe
C.O.R.E.
Dirtbike, Motocross
and ATV School
1982 CJ-7
Jamboree Edition #511
motojoe is offline
post #2 of 11 Old 05-29-2007, 06:50 AM
79cj7reny
1979 CJ7
To test the booster, pump the brake pedal a few times with the engine off. hold the pedal down with light leg pressure. Then start the engine. when the engine starts, you should feel the pedal drop a little and the pedal effort should decrease. If not, your booster is shot.
79cj7reny is offline
post #3 of 11 Old 05-29-2007, 07:23 PM Thread Starter
motojoe
1982 CJ7
Booster= shot. Still does not explane vacuum leak. Thanks for trying...next?
Motojoe
C.O.R.E.
Dirtbike, Motocross
and ATV School
1982 CJ-7
motojoe is offline
post #4 of 11 Old 05-29-2007, 07:40 PM
slacker92104
slacker92104's Avatar
If the diaphram in the booster has a hole in it, that would explain the weak brakes, and the vacuum leak.
'81 CJ5, efi 302, AX-15 5 spd, On Board Air, wrangler spring conversion, Astro van Hydro Brakes.
Soon: Custom cut Dana 44 front, wide trac solid axle amc 20 rear, SOA,
slacker92104 is offline
post #5 of 11 Old 05-29-2007, 07:42 PM
mikepatrick
1981 CJ7
If the booster is shot and you have a vacuum leak then the vacuum diaphram in the booster is leaking. Pull the hose off of the booster and plug it. I bet your vacuum leak goes away.
Slacker beat me to it.
mikepatrick is offline
post #6 of 11 Old 05-29-2007, 07:55 PM
John Brereton
A friend of mine had a bad diaphram in the booster that some how sucked the brake fluid out of the resevoir and into the intake. The exhaust smoked like an SOB.
What's left of a '79 CJ5
3 - 4" total lift
4.88 gears in a Dana 30 and off center ff Dana 44 with disc brakes
258 with TFI /T18 /D18 drive train with Saturn O.D.
33 x 12 DC Mud Country Radials
John Brereton is offline
post #7 of 11 Old 05-31-2007, 03:26 PM Thread Starter
motojoe
1982 CJ7
Problem solved. Installed an MC2100 and that took care of the vacuum leak.
Idles better now. I do need to replace the booster though. Brakes are weak and it takes allot of foot pressure to apply them. Thanks for the help.
Motojoe
C.O.R.E.
Dirtbike, Motocross
and ATV School
1982 CJ-7
motojoe is offline
post #8 of 11 Old 05-31-2007, 04:52 PM
slacker92104
If you have to replace it anyway, you might look into the yj booster swap.
post #9 of 11 Old 06-01-2007, 11:01 AM
CJ5_Fan
CJ5_Fan's Avatar
1980 CJ5
Have you verified the HG level at the booster? You need a minimum of 16 HG and a prefered level of 22HG inorder to activate the booster correctly. many engines with RV cams or just tired motors struggle to reach that level of HG. If that is the case with your rig, you will always have booster issues.
There are vacuum assist pumps that will solve this very easily such as the one by Stainless Steel Brakes :
http://www.jegs.com/webapp/wcs/store...5962_-1_764262
1980 CJ5 Renegade with 304 v8
CJ5_Fan is offline
post #10 of 11 Old 06-01-2007, 11:23 AM
Truck633
GO ONE MORE!!
Truck633's Avatar
Let us know how you like the MC conversion!! I just did mine a couple weeks ago, and I like it so much I am gonna hold off on fuel injection!!!!!
Truck633 is offline
post #11 of 11 Old 06-01-2007, 08:30 PM Thread Starter
motojoe
1982 CJ7
Got a new booster. The old one was toast. Old brake fluid seeped in over the years causing it to go bad.
Yes, I love the MC2100 on it. It starts up easy and runs great. No issues. I recommend the swap to anyone who wants a better carb than the stock Carter BBD.
Motojoe
C.O.R.E.
Dirtbike, Motocross
and ATV School
1982 CJ-7
motojoe is offline
vacuum leak dblock16 Jeep CJ Forum 1 02-17-2007 09:01 PM
Vacuum leak?? Now what?? dblock16 Jeep CJ Forum 15 01-18-2007 09:53 PM
Vacuum leak? Skrappi69 Jeep CJ Forum 1 03-19-2006 10:37 AM
vacuum leak??? MudMonster Jeep CJ Forum 4 07-23-2004 10:03 PM
82 CJ7 vacuum leak. alexvbugman Jeep CJ Forum 1 03-18-2002 02:41 PM
