Is Vacuum/ECM me problem? - JeepForum.com
post #1 of 9 Old 05-06-2012, 08:28 AM Thread Starter
84VACJ7
I have an 84 CJ7 6-258. It starts fine, runs fine.... sometimes. It seems that after it has been running a while the problems begin. It may cut out, may back fire, sometimes both. Once it cuts out it may restart, but then sometimes it has to sit a while before it will. It almost seems to me that when it warms up adjustments are made that throw things off. I'm handy, but not a true machanic. Any ideas? Thanks for any help.
84VACJ7 is offline
post #2 of 9 Old 05-06-2012, 08:48 AM
Trapshooter
First.....Welcome to the Jeep Forum, tons of stuff here for your CJ!
When the engine backfires, is it through the exhaust or the carb?
Sounds like your issue is heat related.
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #3 of 9 Old 05-07-2012, 06:14 PM Thread Starter
84VACJ7
It backfires through the exhaust.
84VACJ7 is offline
post #4 of 9 Old 05-07-2012, 07:57 PM
Trapshooter
Any number of things could be happening. When was the last time the engine was tuned up? Double check you timing and look at the condition of the spark plugs. Pay close attention to the plug insulators, what color are they? You could have something as simple as a vacuum leak that manifests itself after the engine has time to heat up.
Please take the time to fully fill out your profile, this helps going forward when you have questions for the forum.
Do you still have all the emissions components installed on your '84? Is the engine still stock with the Carter BBD carburetor?
Here is a great Web site that explains all the emissions equipment your CJ came with: http://home.sprynet.com/~dale02/home.htm Take the time to look over this information as it will teach you "what is what" under the hood. If you live in an area where you do not have to pass an emissions test you can remove most of that stuff. Plenty has been written here to help you remove the unnecessary items.
Do take the time to unsure your carb is not coming loose where it bolts to the manifold. You can also take some starting fluid and spray around the base, if the idle increases you have a vacuum leak. Look over all the vacuum lines and fittings for any cracks or disconnects. Any open ports are a bad thing.
Good Luck...........
My 401 build:
post #5 of 9 Old 05-07-2012, 09:16 PM
86cj74.2L
86cj74.2L's Avatar
The ignition module will do most of your mentioned things. A bad coil will do the backfire.
Could be both.
86cj74.2L is online now
post #6 of 9 Old 05-07-2012, 10:50 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
LT1CJ7 is offline
post #7 of 9 Old 05-08-2012, 04:06 AM
BagusJeep
1981 CJ7
Have you Nuttered the computer?
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #8 of 9 Old 05-08-2012, 04:10 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Sounds like a bad ignition module, and perhaps a loose manifold bolt, or three.
Matt
Matt1981CJ7 is online now
post #9 of 9 Old 05-08-2012, 02:16 PM Thread Starter
84VACJ7
To all, thank you for the input. I'll check on these things and do some reading. No I have not Nuttered. I'm not real familiar with the process in Virgina and I don't know how hard the annual inspection guys will look at that.
84VACJ7 is offline
cj7 , ecm , vacuum
vapor lock/vacuum problem AMC360!! JeepCJ7LTD Jeep CJ Forum 41 10-20-2015 10:11 AM
old 258 problem with vacuum ? edmon85 Jeep CJ Forum 2 07-12-2011 10:07 AM
1974 Vacuum problem White74CJ5 Jeep CJ Forum 4 02-27-2011 07:11 PM
302 vacuum problem in cj5 79jeepnjeepers Jeep CJ Forum 4 09-10-2009 07:42 AM
Vacuum Problem OldSailor Jeep CJ Forum 4 10-09-2007 01:24 AM
