Vacuum assist Upgrade - JeepForum.com
post #1 of 7 Old 04-07-2010, 04:32 PM Thread Starter
matt1u2
1977 CJ5
I am upgrading my 77 Jeep CJ5 with vacuum assist brakes. It is a Jeep CJ booster. My question is running the lines. There is a large reservoir to the back in the master cylinder and a small in the front. Which one goes to the front and rear. Also do I need to use a different proportioning valves.
Any advise on bleeding brakes. I haven't ran the vacuum hose yet. I have the 304 engine with an edelbrock intake. I also installed wide track axles from an 84 cj7
thanks for the help
matt1u2 is offline
post #2 of 7 Old 04-08-2010, 12:29 AM
cj7guy
I put a vac brake booster on a 78 CJ7 that came with manual brakes. It was the best single upgrade to that vehicle ever, and I did a lot of mods, including fuel injection.
07 JKU - 6spd - LSD rear
cj7guy is offline
post #3 of 7 Old 04-08-2010, 08:10 AM
MikeMCJ
1951 M-38
thanks for the help
I have all the parts and will be doing this swap as soon as I can find the time.
larger res is for the front brakes.
pressure bleeder works best for me, but the speed bleeders look like a great idea (that I have not tried yet). note that you may need to pin the combo valve. Do a search on this site for more details.
As far as the combo (proportioning) valve, I have not been able to verify a difference between drum/drum and disc/drum. Many parts outlets list the same valve regardless of front brake type. Many have swapped over to discs in front and have not seen adverse braking using their original valve.
MikeMCJ is offline
post #4 of 7 Old 04-08-2010, 08:52 AM
jatepper
You do not need to change the prop valve. It will work for any combination of disc / drums.
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #5 of 7 Old 04-11-2010, 05:21 PM Thread Starter
matt1u2
1977 CJ5
I have not had any success with bleeding the brakes. I replaced all the rubber and most of the metal lines.
Like I said I haven't hooked up the vacuum line yet. There is a 3/8 plug behind the carb that I have decided to remove to get the vacuum.
Does the vacuum line have to hooked up to bleed the brakes?
Any advise would be very helpful.
Thanks ahead of time.
matt1u2 is offline
post #6 of 7 Old 04-11-2010, 05:35 PM
alex211
1995 XJ Cherokee
You do not need the vacuum line hooked up or the engine running to bleed the brakes.
95 xj bone stock for now
alex211 is offline
post #7 of 7 Old 04-12-2010, 03:54 PM Thread Starter
matt1u2
1977 CJ5
I hate to admit this but i had the calipers on upside down. Fixed that and I was able to bleed them just fine.
One note for guys that don't have an assistant available all the time. I purchased a brake bleeder from harbor freight that works with your air compressor at 100psi by creating a vacuum. It works great. Easy way to flush old/bad break fluid also.
Thanks everybody for the help.
Matt
matt1u2 is offline
YJ booster upgrade vacuum TJTony Jeep CJ Forum 6 04-08-2010 08:27 AM
Vacuum assist Brakes matt1u2 Jeep CJ Forum 0 02-03-2010 04:38 PM
Vacuum Connection for YJ Booster Upgrade TetanusCJ7 Jeep CJ Forum 9 05-06-2009 06:48 PM
ram-assist steering swampbuddy Jeep CJ Forum 10 02-11-2007 02:12 PM
Vacuum assist pump options CJ5_Fan Jeep CJ Forum 1 06-08-2005 11:45 PM
