Quantcast Vaccume Question - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Vaccume Question
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.com
Old 11-20-2009, 11:30 AM   #16
deltadukman
Ok mike. Thanks for all the help. I am going to unplug the EGR, and block the vaccume off. If that solves the stalling while braking, I will get back on here to let you know and sak for your wisom once again.
deltadukman is offline   Reply With Quote
Old 11-20-2009, 01:25 PM   #17
deltadukman
Mike. I went home at luch and looked at it. The EGR isnt even hooked up, but I could tell that at some point during me doing all this I have unhooked it. So I am going to look. I did notice there are 2 little plugs on the drivers side of the engine, on the block, towards the bottom. They have two vaccume lines that come up to around the carb. One of these plugs with the 2 prongs, is broken. What are these "plugs" called? Can these be purchased?
Old 11-20-2009, 01:39 PM   #18
Mike Romain
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
A photo would help, but they sound like a CTO valve that would shut off the vacuum on a cold engine.
So it would seem you have some open vacuum lines in there. That can be your trouble, open vacuum lines can lean things out. A close inspection is called for.
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Old 11-20-2009, 03:52 PM   #19
mastercraftka
Wanna Be
Even if the EGR is has no line connected to it don't you have to still take it off and block the inlet with a piece of old gasket or something? Just curious?
mastercraftka is offline   Reply With Quote
Old 11-20-2009, 04:07 PM   #20
Mike Romain
Off Road Forever
Only if it is leaking by being carboned up or rotted away. Otherwise it is just closed until it get a vacuum suck through the line.
Mike
Old 11-20-2009, 09:09 PM   #21
mastercraftka
Wanna Be
ok makes sense.
Glock Forum
