v-8 lift ? - JeepForum.com
post #1 of 6 Old 08-17-2002, 06:28 AM Thread Starter
diggy
v-8 lift ?
Hi everyone, I'm new here, been driving Jeeps for years. Anyway. I just purchased a 79 cj5 w/304 and the stock suspension is shot. The rear springs actually arch the wrong way. What I'm wondering is will I have to add a leaf to the front packs for it to sit level? or do the lift companys take that into account?
diggy is offline
post #2 of 6 Old 08-17-2002, 09:49 AM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
I have not found a production lift that works for very long with an AMC V-8. Production lifts tend to work best with the I-6 and sag quickly in the front with a V-8. The guys that have a 4 cyl have the opposite situation and get the rough ride with springs that are really stiff.
I wound up adding a main leaf from a Skyjacker set to my front pack and it seems to be working well so far.
I will have a custom set made down the road - probably Alcan's...
Steve
OldJeepguy is offline
post #3 of 6 Old 08-17-2002, 10:56 AM
CSP
Believe it or not, there's only about 20 pounds of difference between the I6 and V8. A small block Chevy is actually lighter than the AMC I6. There's a lot more block on an I6 than a V8 and that's why it's so heavy.
CSP is offline
post #4 of 6 Old 08-17-2002, 06:19 PM Thread Starter
diggy
Thanks for the info, I guess I'll put on a lift and take if from there.
Diggy
diggy is offline
post #5 of 6 Old 08-17-2002, 07:13 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
This reference shows at least 40 lbs and possibly 100 lbs difference. My front springs came off a Jeep with the I-6 and there was no sag - One month after the install they had dropped 1.5". This is common with my CJ - I am on my 4th set of springs in 8 years.
Engine weights
Steve
post #6 of 6 Old 08-18-2002, 10:11 AM
CSP
Interesting. My charts don't show that much difference so it's a question of what do you believe. What I do know is that my I6 and winch combined definitely weigh more than a V8. I haven't had a bit of problem with the springs sagging on any of the 12 CJ's I've owned over the last 20 years other than normal wear and tear from wheeling them pretty hard.
CSP is offline
Getting rid of 1.5" shackle lift & helper springs - which lift to get now? 1984Laredo Jeep CJ Forum 11 08-01-2013 10:35 PM
SPRING OVER AXLE- roughly how much lift do you get?is it better then a 4" +body lift? jeepcj7 Jeep CJ Forum 12 05-02-2012 09:33 AM
Need Advice, lift, no lift, tire size, wheel spacers??? darwood112 Jeep CJ Forum 3 03-25-2009 11:55 AM
Would someone please explain the difference between a suspension lift and a body lift Giff Jeep CJ Forum 5 09-20-2007 03:49 AM
Shims needed for a 2.5" lift? Other lift questions... Blthomas Jeep CJ Forum 8 07-07-2007 08:36 PM
