Using Power Brake Vacuum For Fuel Evap Canister - JeepForum.com
post #1 of 6 Old 07-19-2014, 10:42 PM Thread Starter
WindKnot
1977 CJ7
I don't have power brakes. Moving the vacuum source for the Evaporative Canister to the Power Brake port would clean things up a lot.
Can anyone think of a reason not to go this route?
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #2 of 6 Old 07-19-2014, 11:04 PM
JeffreyCharles
1976 CJ5
Not having a means of purging the evap canister? Or is it already gone?
Jeffrey Charles
http://jeep.smallcraft.net/
JeffreyCharles is offline
post #3 of 6 Old 07-20-2014, 01:35 AM
bruteboy
it may cause driveability issues as it would act like a vac leak when purging. it should be tee'd into the pcv line.
bruteboy is offline
post #4 of 6 Old 07-20-2014, 05:40 AM
Mike Romain
The purge is just looking for manifold vacuum so that should work fine as long as the trigger is still ported.
Mike
Mike Romain is offline
post #5 of 6 Old 07-21-2014, 09:35 AM Thread Starter
WindKnot
1977 CJ7
Thanks guys. I looked again and then I was "inspired" to look at the FSM to see what it said. (well, duh, dummy! ) You guys are right, all it wants is a vacuum source.
It wasn't set up correctly when I bought it. In fact the fuel return line had somehow disappeared as well. Since I'm rebuilding and considering a future move to FI I want to restore the return line. The Evap was there but the original air cleaner was gone and the purge hose wasn't hooked up to anything.
The book says originally the purge hose was just hooked into the air cleaner horn; it doesn't require that much of a vacuum at all. I think you're right in that although the power brake port would establish the vacuum, the airflow might be too large and cause problems.
Thanks for the sounding board.
WindKnot is offline
post #6 of 6 Old 07-21-2014, 10:03 AM
Mike Romain
You have the old fashioned canister then with no purge valve on it. It would cause a vacuum leak for sure if hooked to manifold vacuum. I have seen folks just drill a hole in the snout of the intake and solder in a copper tube at right angles to the airflow for picking up the purge line. They flared the end of the tube so it fit tight in the hole from the top. Even an epoxy like JB weld would likely hold the tube in place, but solder would be best.
Mike
