Using factory air cleaner with MC2100? - JeepForum.com
post #1 of 10 Old 06-23-2013, 01:12 PM Thread Starter
Cashcrazy
1983 CJ7
I was able to find some documentation on how to build an adapter to make the MC2100 work with the factory air cleaner and now I can't find it anywhere. Has anyone seen any instructions for this floating around?
Cashcrazy is offline
post #2 of 10 Old 06-23-2013, 06:11 PM
petey156
1977 CJ5
What is your factory air cleaner? As long as its not the single barrel air cleaner it should work.
petey156 is offline
post #3 of 10 Old 06-23-2013, 07:01 PM
arkiemurph
Can't just get one off a Jeep with a 304? They came with the Motorcraft crab.
Murph
Love thy neighbor, but don't mow down the hedge.
arkiemurph is offline
post #4 of 10 Old 06-23-2013, 09:30 PM
skizriz
1978 CJ7
I made an adapter yesterday for mine. I used a 5" stove pipe cap to make it out of. Cut a 3" hole in the top, a few tack welds, and sealed it up.
Sent from my iPod touch using JeepForum
skizriz is offline
post #5 of 10 Old 06-23-2013, 10:31 PM
CSP
If I were trying this I would find a very common air cleaner housing off just about any GM or Ford V8 from the 70s or 80s that had the same 5-1/4" opening. I would cut the bottom out of it and out of the stock 2bbl housing. The weld the bigger opening bottom into the stock CJ housing.
CSP is offline
post #6 of 10 Old 06-24-2013, 07:46 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Is the OP talking about a I6 or V8
Makes a difference
John Strenk is offline
post #7 of 10 Old 06-24-2013, 08:30 AM Thread Starter
Cashcrazy
1983 CJ7
I have the 4.2 with the offset breather. This is my third jeep and never had the pleasure of owning the AMC304. I used a weber with an open element on my last Jeep, but I am trying to maintain a stock appeareance with this one. I have not thought of using stove pipe. That is an excellent idea. I am also considering using exhaust pipe to build something. Thanks for all the ideas.
post #8 of 10 Old 06-24-2013, 08:53 AM
CSP
If the OP had a V8 the factory air cleaner housing is the same as that used on the MC2100. The factory carb on the V8 is the MC2100.
CSP is offline
post #9 of 10 Old 06-24-2013, 10:29 AM
John Strenk
1976 CJ5
This is probably what you are looking for:
In this post:
http://www.jeepforum.com/forum/f8/wr...ousing-995215/
Looks like Dislsmoke would make one for $45.00 but that could change.
he also made one for the GM TBI.
post #10 of 10 Old 06-24-2013, 11:14 AM Thread Starter
Cashcrazy
1983 CJ7
John you are the man!!
