used arb question - JeepForum.com
post #1 of 6 Old 10-04-2011, 09:04 PM Thread Starter
joes1982CJ
used arb question
might be getting one used for my amc 20. with that said im curious if there are any disposable parts i should be concerened about that i might have to purchase in order to reinstall..i know i will need an install kit but are there any "arb specific" parts that i might need?
thanks in advanced
joes1982CJ is offline
post #2 of 6 Old 10-04-2011, 09:17 PM
BagusJeep
1981 CJ7
Well you had me scratching my head with this one, what on earth is an "arb". At first I thought maybe the C on your keyboard was sticking and you meant "carb". However you refer to an AMC20 which is an axle so you are referring to a ARB air locker?
There is an o ring seal in the housing that you will want to replace as a matter of course and of course the nylon air line and fittings up to your compressor. The relay and solenoids and wiring kit should be good to go and the locker itself is pretty reliable.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #3 of 6 Old 10-04-2011, 09:24 PM Thread Starter
joes1982CJ
yeah sorry arb air locker is what im talking about. so this o ring, im assuming i can purchase this from arb i would imagine. i thought i read here that there dont make this locker (for the amc 20) i guess i will call them in the am
post #4 of 6 Old 10-04-2011, 11:23 PM
84scrambler
1984 CJ8
If its like the ARB for my dana 44 then you should look into a set of misc. shims and a new bearing for the bigger side. These were specialized parts I needed for my install that weren't available at just any store. I ended up getting an assortment of shims from a mechanic that installed them so its worth asking those guys as well.
84scrambler is offline
post #5 of 6 Old 10-04-2011, 11:37 PM
BagusJeep
1981 CJ7
They do make one for the AMC20, it is around $1,000 plus the compressor. Plenty of places stock spares and arbusa would be a good place for technical advice.
post #6 of 6 Old 10-05-2011, 07:02 AM
CSP
ARB changed the bulkhead fitting where it goes through the axle housing to a different design. It would be worth your while to upgrade this ARB to that type of fitting.
Call ARB's customer support line. They are extremely helpful and can make the proper recommendations and send the right parts.
CSP is offline
New lift question - shackle angle question *Thunder Jeep CJ Forum 2 10-09-2009 08:53 AM
Timing question & adjusting carb question. jatepper Jeep CJ Forum 8 02-22-2009 08:29 PM
Computer question and FUEL INJECTION question MontyWilco Jeep CJ Forum 4 10-11-2006 09:21 PM
